The particulars:
2.4 liter, 4 cylinder automatic.
195,000 miles.
Bought new. Regular 3 to 5k oil changes (mostly 3k).
Dinosaur oil. 5w30. Pennzoil, then high mileage Pennzoil at about 100k. Fram filters - the one with the textured end.
No oil use or leaks. Gets about 22 mpg.
Just switched it to occasional use only. I try to go through a tank of gas a month which is 250 to 260 miles or roughly 3000 a year.
If I wanted to just change oil once a year, what would you recommend, including filter? Alternately 2 times a year if that would be better. Thanks.
195,000 miles.
