2003 Matrix, 100K miles, 1ZZFE valve cover removed pics
North of Seattle
Valve cover gasket was leaking and the chain tensioner o-ring is a known issue so did them both. Oils that I have used in this vehicle since new are Mobil 1, Amsoil, Redline, Mobil 1 High mileage, Valvoline high mileage, and currently, Valvoline Restore and Protect. Looks good for now, happy with the current condition.
Also looking good for the mileage and appreciate the higher mileage info from here:
Nice & clean indeed! You’ve certainly used the premium oils on the market. What grade of oil have you been using?
Most Toyota engines have a maple syrup varnish to them. Not that the varnish was doing any damage, just saying! How’bout some pics of the rest of your car after 23 years?
That's a good looking valve train cleaner than the soup bowls in my kitchen cabinets.
Looks fantastic! Thanks for the photos. I'm running the first of round Valvoline Restore and Protect in my 1zzfe to hopefully get mine that clean. Mine had a fair amount of vanish the last time I did the valve cover gasket IIRC around 160k. I plan to do side by side photo of the before and after photos when all is done.
How many oil changes have you done with Valvoline Restore and Protect before popping the valve cover?
wow, so that's what that motor is supposed to look like! (I have 2006 with 221K). Yours looks beautiful!
You may also want to replace your vvt solenoid o ring and your cam position sensor o ring (both easy to access from the front). Every o ring on mine was leaking when I got the car last year. Only o ring still waiting to be done is the crank position sensor o ring.
Were the seals brittle? This is similar in age to the Lexus V6 that I got for my grandson. The elastomers were so hard they cracked apart as you removed them. I was disappointed given the Toyota reputation for robustness. The steel and aluminum parts looked beautifully manufactured.
Thanks, I'll have to grab some pics after I give it a good bath, been dirty for a while now. I've always used 5W or 0W-30, currently the Valvoline Restore and Protect 5W-30.
This is the second round but only did about 2000 on the first round and about 800 on this one.
Thanks for the heads up, Ill take a look at those and might do them when I do the Intake manifold.
Yes, it was. broke in several places and on the sparkplug hole conjoining bridges, a small piece fell into the valve head area but was not difficult to get out. New gasket is a Felpro which went on fine (used Permatex ultra black in the required spots) but the included valve cover gromets will get changed out once I get better ones.
