Panther gurus, help! What could cause the digital gauges to flicker? I've spent quite a bit of time on Google, no luck. Let me clarify: the entire gauge panel flickers (and by flicker I mean there is a random and frequent bright/dim flicker). No other malfunctions, no other problems. This doesn't seem to be a voltage issue because the random flicker is constant (idle, light/heavy throttle, light/heavy power use). Alternator seems fine, no starting/running issues. FWIW, I'm not experiencing any headlight issues...
Any ideas?
Thanks in advance!
Any ideas?
