2003 Corolla oil change interval opinions
Originally Posted By: 01_celica_gt
That engine already burns oil or will eventually from the oil return holes being clogged, only 4 holes, the updated pistons have 8 holes instead.
I have rebuilt 4 so far with different mileage and...every single one had stuck oil control rings with fully carboned up oil return holes.
Use a full synthetic at a reasonable OCI (your previous 6k is just fine, just go by mileage and not time) and this will delay your oil return holes from being clogged up.
I believe that 2002 was the last year before Toyota corrected the 'stuck ring' problem on the 1ZZFE.
The 2003 was the first year of the newer (9th) generation Corolla and didn't have this problem.
My b-i-l has over 230K on his 2004 and it's had synthetic only @ 10K intervals for at least the last 50K. It uses about a quart (or less) during the OCI.
The 1ZZFE after 2002 is not prone to sludge if reasonably OCI's and/or syn. are used.
05+ is when the issue was fixed, I own a 05 complete engine that I just fully rebuild, came with the updated piston.
Also was offered a 04 complete short block which did not have the updated pistons.
I got my parts from a Toyota Tech...I'm sure he and I know more then you about the 1ZZ-FE engine. Monkeywrenchracing.com sells those engines, they will tell you the same. Unless you are the engineer of the engine I'm sure your clueless still.
Nonsense. I have discussed this with multiple technicians at Toyota and it only applies to the 8th gen. I have a good friend who works there as well.
OP, I have been using Fram Tough Guards since the Pure One's have been ripping along with Mobil 1 Advanced Fuel Economy following 7500km intervals per mfr recommendations. I am too impatient to run longer intervals so I keep them short. Im confident you could go 10k miles without issue but if your current habits dont bother you keep following what you already do, you have confirmation its working. Also, do change the PCV valve, cost me about 11$ at the dealer and takes 5 mins to change. I changed mine recently and the very slight consumption it had seems to have gone away completely. Be sure to get OEM PCV. Costs 2-3$ more so why bother with Fram? My consumption was almost half a quart per 5k miles (slightly less than 1/2 quart). This car is not fussy about oil type or brand. Change your PCV and next change use a TG filter and keep doing what you are doing. Im at 120k miles and I couldnt be happier with it. How often do you get the transmission fluid changed? Another thing that is very easy to do by yourself and will help keep it running for years to come.
Changed out the PCV at around 90,000 miles with OEM and it wasnt clogged. I actually just did a drain and refill on the ATF with toyota type IV, 3 quarts. My atf schedule has been, 62k dealear flush, 88k drain/refill type IV and 125k drain and refill type IV. Also just did a drain/refill on antifreeze with toyota long life red coolant. It was last flushed by dealer along with ATF at 62k back in 2010.
Clubber: Don't worry about sludge, the 1ZZ-FE in any generation is not one of the Toyota sludger engines.
I'm not sure what got celica so
but I also believe he is wrong. The new pistons w/ 8 (vs 4), larger, oil return holes were added in the 2003 model year, but phased in (maybe based on part availability) so there are some 2003s that still have the old pistons (friendly_jacek on this board had one of them). It's surprising to hear an '04 block had them, maybe it was rebuilt with old stock pistons?
Either way, it's pretty unlikely you have a bad set, especially considering the unknown previous maintenance yet no (noteworthy) oil consumption. My 02 needs 1qt/2000 miles, varying by usage. You sound fine at your interval, and could likely extend it.
Why did you have to rebuild the engines so soon?
Why so defensive? It's not like he was personally attacking you.
I stand corrected.
I have known many people with 9th gen. Corolla's (2003 to 2008) with the 1zzFE who use no oil. I even thought I read that the problem was corrected earlier than 2005 but I could be (actually I now know I am) wrong. I changed the oil in my b-i-l's 2004 in February and checked it last night.....after 7600 miles it took a half a quart to bring it from 1/4 above the add line to 3/4+ above.....hardly what I would call problematic on a 233K engine.
I do agree with ThirdYe that you got overly defensive especially since I started my post with the words...."I believe" which means I could be wrong....I've been wrong before and I'll be wrong again...
Whatever the manual says.
Using different weights or filters is ok (I never had any adverse effects), but I'd stick to the interval and oil type (conventional or synthetic) that's stated in the manual
I'd stay with what you're already doing.
I have a 2001 Corolla and was doing the same OCI you're doing before my Truck Driving job went OTR. I ran Conventional for it's first 60,000 miles, changed every 3000 miles, and I was averaging about 450 miles per week with my commute to and from work each day. At 60,000 miles I switched over to Synthetic and increased it's OCI to 6000 miles. It now has about 125,000 miles, but it doesn't get driven but maybe 3000 miles per year. I still run Synthetic and change it once a year, which I'm sure is total overkill.
It will be my daughter's first car in less than 3 years, -which is cool as I bought the car when she was only 3 months old!
