2003 Chrysler Sebring Power Steering questions
Tacoma, Wa
My brother's 2003 Sebring (2.7 v6) has been "chirping" sound when it's first started and when the steering wheel hits the bump stops of the power steering. It only does it cold, so in hoping to help resolve the issue, I'm putting in new Napa ATF+4 fluid. I also want to plumb in a Napa #3033 fuel filter into the power steering system to collect debris that's in it.
What is the flow direction of the fluid so I plumb the filter correctly. Does the fluid flow out of the reservior through the front 3/8" line?
Put in some fresh fluid with some MMO... Run it for about 20 minutes and dump the fluid and refill with just fluid.
Most likely some gunk in the system.
Chryco pumps aren't usually problematic...
