2002 Silverado 5.3 Tranny
The transmission works like when original. The supposedly heavy duty parts have no effect on what you feel when driving. Who knows what I really got. The only thing that worries me is not being able to feel the shift between Park and Drive. I'm not sure if there is a long term negative effect. I mentioned it to the Trans Tech and he got in the truck and said it was fine. I repeated to him that when I purchased the truck NEW there was a normal natural shifting feeling from P to Drive. He said not to worry. If anyone here can give me advise or an explanation on the shifting I will appreciate it
Originally Posted By: Gito
I think I will go for the complete rebuild and I will request synthetic ATF unless otherwise directed or advised. I know that synthetic will do better in hot climate. I do plan to keep my truck. It has a solid engine, straight, dent and rust free body. The truck still looks brand new and no motor oil leaks whatsoever........I want to get at least another 200k. I think the next thing I really have to pay attention to is the differential. I still feel that 187k transmission failure is premature and could possibly be heat related. As for the transmission cooler, I'm in southern California and I'm wondering who installs such coolers and who is qualified. What do I watch out for? any recommended shops? I do drive in very hot climate most of the summer...
Ask the shop who rebuilds your transmission to install a cooler and a in-line filter on one of the cooler lines, you will be amazed at the amount of junk that the in-line filter catches.
Originally Posted By: EricG
Ouch, thats a hefty markup. I rebuilt the 4L60E in my 95 Z71 for under $700 using most all of the common upgrades and a reman. convertor. This will give you an example of the cost of parts, (Retail mind you)!
http://www.makcotransmissionparts.com/
I believe the correct term is a SoCal mark up. OP do you plan on doing a annual ATF pan drop and refill? Keep us posted on how your transmission is holding up.
