2002 mdx, 74,000 miles.
Just got it, repair records show regular engine oil but no indication of ATF refresh. Dealer maintained, mechanically in great shape, though occasional "surging" like ignition or problems with TC lockup, such as 3-4 pulses per second.
Drain took forever. I actually got 5 qts out... I'd start it for a few seconds and shut it down... steady 3/16" bead of "washed-out-red" fluid for forever. Fluid never foamed and tranny never rumbled during the brief start-up periods. (I know this is controversial, I've done it sparingly and never had problems).
5 qts amsoil ATF in.
also did valvoline 5-30 synpower OC at same time.
TRans definitely feels different, Amsoil seems to grip just a little quicker than Z-1 did. That AT didn't mush into gears before, and while it's not a huge difference, you can tell it snaps in to gear with a little more kick than before, unless you're near WOT (not our normal habit, but for the test drive I did). It's not alarming or out-of-place, just an observation.
Here's the interesting bit. Now, this also involved an OC to Valv. Synpwr at the same time, but I've rarely seen a mpg improvement from motor oil... wife was previously averaging 15.5-15.9 mpg in town in this 4000 lb fuel pig. She's seeing 17.4-17.0 mpg averages now, all with A/C on.
Mike!
Mike!
