I am not an Amsoil fan or user but I would say without pause that the Amsoil did not cause your failure. It is a very good oil. You could run it again and be fine.
If you just don't want to run it again because of what happened( that too is 100% okay and don't let anyone tell you otherwise )then pick any quality oil you like. Royal Purple, Redline, Pennzoil Platinum, Mobil 1, Quaker State Horsepower, Valvoline Synpower, etc... I assume you wish to run synthetic as you were before?
You could also run one of the high mileage engine oils. I like the Valvoline MaxLife version but most all of the other name brand oil mfg's offer one. Your replacement engine has 79K on it so one of these oils would make a lot of sense. I actually would recommend you run MaxLife.
