Hello,
I need some general advice. I ordered my G30 Van in 2002 and was originally a company fleet vehicle. As indicated in the title, it has the 8.1L Vortech... I loaded it with full power, 3.73 posi, HD trailering package - essentially the works. When new, I also had it upfitted at Commercial Van Interiors.. it wasn't used much, when I bought it from the company in October 2009, it only had 10K miles. This was all city street driving with minimal loads, no towing.
My question is what oil should I use to extend the life of my new Chevy Express with a Big Block? It uses oil, about 1 quart every 1000 miles... I guess it's normal for this 496ci engine.
The company had the oil changed in regular intervals.. they used Pennzoil Conventional 5w30. I recently changed to Mobil 1 5w30 Synthetic.. It appeared to clatter more at start-up, when cold, at idle, with the Mobil 1 oil and filter. Therefore, I removed the Mobil 1 oil and filter and went back to the Pennszoil conventional 10w30 and Purolator oil filter to play it safe. One tech recommended I run a bottle of GM EOS and drive it for good break-in period on the freeway.
Ultimately I want to use it for towing... it has a heavy duty class 5 hitch.. engine never runs over 180 degree coolant temps.
Any insight on the 8.1L will be grealty appreciated...
Thank you
Thank you
