Hello all! Long time lurcker - first time poster...
SAMPLE DATE: 04/22/05
MILES ON OIL: 7,106
MILES ON UNIT: 33,117
MAKE-UP OIL ADDED: 0 qts
This Sample/Universal Avgs.
Aluminum 5/4
Chromium 1/1
Iron 40/18
Copper 12/7
Lead 2/2
Tin 0/1
Molybdenum 63/59
Nickel 1/1
Manganese 0/1
Silver 0/0
Titanium 0/0
Potassium 2/1
Boron 67/66
Silicon 20/11
Sodium 6/6
Calcium 2608/2303
Magnesium 10/247
Phosphorus 750/760
Zinc 883/910
Barium 0/0
INSOLUBLES - 0.4%
WATER - 0%
ANTIFREEZE - 0%
FUEL - FLASHPOINT - 375ºF; should be >375!
SUS VISCOSITY @ 210 ºF - 68.6
BLACKSTONE COMMENTS: The highlighted metals are probably from lingering wear-in, if you've been running long oil changes from the start. If you have been running shorter oil changes and this is the first long one, then the iron and copper may be your Audi's way of letting you know it prefers shorter oil changes. The TBN read 2.0, not much active additive left. We consider 1.0 or lower to be too low. The slight fuel
dilution is from city driving or idling and should disappear next time if you take her out on the highway before sampling. Check back to monitor. (My comment: Dealer performed oil change and took sample. Car sat for 4+ hours before and I don't know if sample was taken mid-drain.)
Some history: 8,000 miles on factory fill then about 4,000 on ???, probably dealer dino. Then made the switch to M1 0w40. Changed out first M1 fill at 3,000 which was in there for a year as car sat alot during that period. Then went 10,000 over 9 months and then this (my first tested) sample which was in over the last 6 months - obviously over winter. Car sees 60/40 city/highway and is run fairly hard. I have yet to install any performance mods yet. Still has original air filter/plugs, etc.
Any comments? Could the high iron and copper really be from lingering wear-in? Oh yeah! One final note - I threw BMW/Mini Syn. 5w30 (A3-rated) in this time. They were going to use it last change (paid service) but I preferred the M1 I brought with me so I took it home with me. I assume this should last me 5-6,000 miles until my 40K service...
MILES ON OIL: 7,106
Aluminum 5/4
Chromium 1/1
Iron 40/18
Copper 12/7
Lead 2/2
Tin 0/1
Molybdenum 63/59
Nickel 1/1
Manganese 0/1
Silver 0/0
Titanium 0/0
Potassium 2/1
Boron 67/66
Silicon 20/11
Sodium 6/6
Calcium 2608/2303
Magnesium 10/247
Phosphorus 750/760
Zinc 883/910
Barium 0/0
INSOLUBLES - 0.4%
WATER - 0%
ANTIFREEZE - 0%
