2002 4.8L Chevy - 5k oil changes?
So, officially stating that it's O.K. to drive 5,000 miles with conventional oil?
My first couple of oil changes on my 2003 I did and then switched to Mobil 5000. Then around 100k started using Mobil 1.
I know a couple of fleet guys that had to use conventional in the fleet trucks due to cost. These were construction trucks that were loaded down daily and did not have an easy life. The only issue they had were 6.0s with piston slap.
Another fleet was for a large lumber/logging company that were used by timber buyers and plowing out logging landings. Fleet guy was a family member and was ecstatic when they switched to Mobil 5000. They were using whatever was in the bulk bin prior to that and it wasn’t consistently the same oil due to price. No breakdowns on engines or transmissions in the trucks which were all half tons with 5.3s. Their older trucks had 5.7s in them.
If I was OP and had his truck I’d use conventional and take a sample at 3k and post it up here just for fun as long as he’s not short tripping a lot and continue until 5k if the sample is good. You won’t know until you try. He also said he’s used synthetic since new until he used the blend and it quit leaking. Run the blend and go on with life or don’t.
You also suggested to a member here to not tow with their pickup until 10k miles were on it. That’s pants on head type advice.
340k and you found a miracle oil, get some more of that exact batch if possible, stash it away, and cross your fingers.
I remember when fleets used Mobil 5000 as a luxury oil in their LS engines. Those engines were built to last on crap oil at 5000 mile changes if they were lucky, usually went longer though. No need to over think this.
me too. mobil clean 5000. used in it my 04 z71 for most of its miles,.
Mobil clean 5000, specifically. But your question is silly. Can you drive 5000 on conventional? Sure depending on engine, use, idling,short trips, etc. waiting for a gotcha moment?
In some cases, 5000 miles in a healthy powerplant is absolutely fine, especially an LS with a SQ oil these days.
2000 Silverado here. 4.8L pushrod V8. VWB 5W30. 5K mile OCIs. Never burned a drop of oil and I drove it hard. Transmission gave out at 300k miles. I did 50k mile Jiffy Lube flushes via ATF line to radiator on that BTW.
  • Like
Reactions: wlk
Mobil clean 5000, specifically. But your question is silly. Can you drive 5000 on conventional? Sure depending on engine, use, idling, short trips, etc. waiting for a gotcha moment?
I've been driving thousands of miles with Mobil Super which is the same oil as Mobil 5000. I've never driven more than 4K miles. And I don't think it's good for 5K, even 4K miles is questionable. I've been using it in my 100,000 miles Civic for years.
Saying 5,000 miles on the bottle it doesn't mean it's safe to drive that much. On current full synthetic oils the label says 15,000 and 20,000 miles but I don't know a sane person to drive that much.
Also, what does healthy powerplant mean? The OP vehicle has 340,000 miles on it.
If you dont know wh\at th\at is, I dont know wh\at to tell you.
