Friend of mine pulled a weak battery out of his car. Sat overnight with no battery. Next morning gets a new battery, installs it. Everything works but when you attempt to start it, it does absolutely nothing.
Checked all connections and and battery volts. All are fine.
The battery light and security light flash back and forth. I found the relearn procedure where you attempt to start it, leave it in the “ on “ position for 11 minutes, turn it off for 5 seconds and repeat 3 times.
Now the security light is off, but it still won’t start. I HIGHLY doubt it’s a starter problem. The car is really nice and only has 80k on it.
Everything worked 100% before changing that battery.
Any ideas ?
Any ideas ?
