2001 Jeep Cherokee Sport (Father/Son Project)
Rock Auto is a great place to find dis parts, just watch the shipping costs…
Oil filter - if you have the room, Wix 51515 is same base and bypass, just longer. Wix 51773 is even longer…
Transmission - TES-295 is a great Dexron III substitute
You may be able to run Dexron III / TES-295 as power steering fluid…
Rock Auto is where 90% of the parts came from and all of them far cheaper than I could buy them locally.
I can check for a different brand of filter that crosses to the WIX because they are rock catchers, but appreciate the number of the filter. EDIT - is this a PH8A (FL1A) filter? Seems like it.
The Valvoline Dex/Merc ATF was $18 a gallon so not too bad and was on the shelf at WM.
Jeep specifically states not to use ATF as power steering fluid. The FRAM fluid is $20 a gallon and after we complete the next flush, he should be good for a long time.
As long as you get 100% of the old coolant out, which I know I did.
But the all makes all models long life stuff is probably the better option. I've got that in my Sonata now.
The Prestone I bought is the 10 year/300K mile stuff. I see they make a platinum version that is good for 15 year/350K miles (though I would not leave it that long). It is compatible with "everything" based upon what I see on the label, so I may go and swap it and call it good.
Nice. If you haven't already, you might want to check out the various XJ forums. The one I recommend is NAXJA which I once frequented when I had my 2000 Cherokee XJ.
If you plan on going off road, one recommendation I would make is upgrading the mechanical cooling fan clutch. You can put in a fan clutch from a ZJ (Grand Cherokee of the same vintage) to help with cooling as it engages sooner than the stock XJ fan clutch.
Did it come with any skid plates/tow hooks? It is something to consider if you ever do take it off road. For some reason, not all 4x4 XJs had them.
Every time I ask why no one ever knows. Pretty sure even @Trav has said yeah, no good reason.
I call BS on Chrysler, the p/s system on an XJ is stupid simple and a light hydraulic fluid is a light hydraulic fluid. There's simply no way the system can "know" or care what's in there unless someone can point me to seal materials or something that like power steering fluid but degrade when exposed to ATF
Yep; it is on the list of things to do. I have a Wrangler and am in that forum quite frequently and find they are great resources.
There are no skid plates or tow hooks (sadly), it is a Sport so not so loaded. Works out though because if they are anything like the OEM skids that came on my Wrangler, they were not worth having. Aftermarket works best for that.
I will check into a new mechanical fan clutch for a 2001 GC, though the photos on Rock Auto show a different mounting type for the GC versus the Cherokee. One of the other guys posted above about the potential for head cracking and though I have not checked to see if I have that model head, I want to take some precautions with the cooling system to minimize the risk. It does have the factory fan shrouds on it so that is one less thing to worry about.
Thanks for the tip!
It's like $2 a gallon difference for the correct PS fluid versus using ATF. The OEM fluid was not ATF so (for me) there is little reason to use ATF.
  • Haha
Reactions: D60
Wix 51515 is Ph8a…
Wix 51773 is Ph977a, holds a quart more than the 8a
I use a lot of them in Kubotas for HH164-32430…
The 51773 is twice as long as the OEM Kubota…
Wix 51515 is Ph8a…
Gotcha--thanks for the information!
You won't fit a big filter on it unfortunately.
I think the TG8A would fit (about 1.4" longer than the TG16), but the 977A would be too long:
TG16 = 3.688"
TG8A = 5.105"
PH977A = 6.750"
Long read (photos to follow soon), but gear heads may enjoy it:
Started a father/son project with my youngest a few weeks ago. I had bought him a new 2020 Challenger in the spring of 2021, but he went off to military college later that year and they would not allow him to have a car on campus until his junior year. I subsequently sold in the madness of COVID and made back all the money spent on it plus a bit more.
Fast forward to a few weeks ago and my neighbor across the street put a 2001 Jeep Cherokee Sport up for sale and was asking $3500. He disclosed an intermittent electrical issue where it would not start from time to time, but you could short circuit the starter solenoid and it would start. We test drove it and it ran fine with noises or issues. He dropped the price to $3000 so we bought it.
It had 71,114 miles on it and almost everything was original including most of the fluids. The interior was like new and the exterior is in great shape except for some hail damage (pictures to follow). Since the middle of July, we have performed an extraordinary amount of maintenance including changing a fair number of worn parts. We did not take photos of the work we did, we were too messy and busy to think about it, but I will describe it here.
Fluids:
1. Engine oil (4.0L L6); surprisingly not as bad as I expected but had unknown miles and had a jobber (FVP) filter on it. Replaced with a FRAM TG-16 and 6 QTs of Rotella Gas Truck SN oil. It does not burn oil but does have a few leaks. We will change it again after replacing the valve cover gasket and PCV parts.
2. Power steering fluid; it was dark brown when we started and now it is pale yellow (it was the original fluid). We ran a gallon of FRAM steering fluid through it via the “turkey baster method” using a large vacuum “syringe”. Will run another gallon through it before he heads back to college to bring it as close to clear as possible.
3. Transfer case (NV231); it was dark red with ample sparkles in it (it was the original fluid). Replaced it with 2 QTs of Valvoline ATF+4 (used part of the first quart to flush it). Will replace it once more before he heads back to college.
4. Transmission (Aisin AW4); it was reddish chocolate in color though it did not smell burned as near as I could tell it was the original fluid and definitely the original filter. Of all the fluids, this one was the worst. We ran 4 gallons of Valvoline Dex/Merc (Dexron III) through it before it improved in color—having a drain plug and dipstick made this a breeze. The transmission shifted normally and when I pulled the pan there was no clutch material in the pan (no debris at all) and the magnets had the usual paste on them, so I was pleasantly surprised. The filter which is a screen type and had no debris on it. We plan to change the fluid once more before he heads back.
5. Front axle (Dana 30—M186); it was moderately dark and was the original fluid. Lots of sparkles in the oil. Reinstalled the OEM cover with a new gasket and almost 2 QTs of Valvoline 75W-90 gear oil.
6. Rear axle (Chrysler 8.25”); it was very dark with sparkles in the oil and in Chrysler’s infinite wisdom they designed a rubber plug for the cover fill hole. It was hard and had a hole it and was subsequently leaking. It was not low, so someone (other than the neighbor) had been checking and filling it. I purchased a new rubber plug and reinstalled the OEM cover with a new gasket and added 2 QTs of Valvoline 75W-140. It has started leaking again (big surprise) so I purchased a blemished after market cover that has a threaded fill plug and will install it soon.
7. Radiator; it was dark and brownish. We are running radiator cleaner through it and will replace the original fluid with Prestone “Green” mixed at 60/40 with distilled water along with new heater and radiator hoses. The overflow container will be pulled out and bottle brushed to remove the crud from inside it.
8. Brake fluid; it was blackish. We had it flushed at Brake Plus prior to replacing all the brake system including hoses (except the master cylinder). New DOT4 fluid was installed and will be flushed/bled again now that the system has been installed.
PARTS:
A. Electrical:
1 ea. Diehard Gold Group 34 battery
1 ea. Standard Ignition Starter Relay
1 ea. Standard Ignition Starter Switch
1 ea. AC/Delco Gold Starter
2 ea. Holley 5x7 LED Headlights
The starting issue was caused by a “Silencer” alarm system which was not coded to the aftermarket key fobs, did not have the “key” in the socket, and was likely just broken/failed. It was ripped out and all wiring restored to OEM. The former owner had Walmart “install the cheapest battery possible” so a (N)everStart Group 26 (should be 34) battery was installed. It was pulled and the Diehard Gold took its place.
I replaced the switch, relay, and starter as preventative, though the former owner had replaced the relay and starter in his quest to find the electrical issue (which he left the Jeep at a shop for over a month, and they could not find the problem). The starter did made some noise when cranking and given the number of times the solenoid had been shorted to start it, it was replaced as a preventative measure. There have been no starting problems since the removal of the Silencer.
As with halogen headlights from that era, they are dim and yellow, even when turned on bright. New Holley LEDs have been ordered to take their place, which should markedly improve the visibility and allow for safer driving.
B. Engine:
6 ea. Autolite XP985 Spark Plugs
1 ea. Fel Pro Valve Cover Gasket
1 ea. Gates Belt
1 ea. AC/Delco Outlet Heater Hose
1 ea. AC/Delco Inlet Heater Hose
1 ea. Dorman PCV Intake Manifold to Valve Cover Hose
1 ea. Dorman Front of Valve Cover Hose
1 ea. Dayco Lower Radiator Hose
1 ea. Dayco Upper Radiator Hose
1 ea. Mopar PCV Kit
2 ea. Prestone Antifreeze/Coolant Concentrate
3 gals. Distilled Water
2 ea. Gunk Engine Degreaser
2 ea. Car Washes
2 gals Fram Power Steering Fluid
1 ea. FRAM Air Filter
1 ea. FRAM Oil Filter
6 qts. Rotella Gas Truck 5w30 Oil
We replaced the NGK sparkplugs (which did not appear to be original and were almost finger tight) with Autolite XP iridiums. The engine ran fine as is despite the air filter housing cover not being latched and the oil leaks all around. The valve cover and PCV is leaking, and we will be replacing the valve cover gasket and PCV in conjunction with the heater/radiator hoses since they have to be moved out of the way.
The serpentine did not appear to be original, but it was hard to tell. I changed it from a preventative point of view. The engine is MPI and this was the final year for the 4.0L L6 in the Cherokee so it is as updated as possible. The power is smooth with plenty of low end torque and it idles quietly.
C. Suspension/Brakes/Body:
1 ea. Anco Rear Wiper Blade
2 ea. Trico Front Wiper Blade
1 ea. Bendix Brake Shoe Kit
1 ea. FVP Brake Drum Hardware Kit
1 ea. FVP Brake Drum Kit
1 ea. FVP Rotor Kit
1 ea. Powerstop Caliper Kit
1 ea. Raybestos Rotor Pad Kit
1 ea. Raybestos Driver's Brake Hose Kit
1 ea. Raybestos Passenger's Brake Hose Kit
1 ea. Raybestos Rear Brake Hose Kit
1 ea. Gabriel Front Shock Kit
1 ea. Gabriel Rear Shock Kit
1 ea. Monroe Steering Damper
1 ea. AC/Delco Rear Sway Bar Bushing
1 ea. Dorman Track Bar
2 ea. Quick Steer Rear Sway Bar Link
1 ea. Dorman Front Sway Bar Assembly
1 qt SuperTech DOT4 Brake Fluid
2 ea. Brakes Plus Fluid/Bleeding Service
1 ea. Ball Joints/Steering System Replacement
3 ea. CRC Brake Cleaner
This is where the bulk of the work happened. Dry rot took out most of the suspension components and so all the sway bar mounts, and end links had to be changed. I bought a new front sway bar due to the corrosion that was on it. I could not find a rear bar so that one will have to be reused. Some of the lower hanging components had quite a bit of corrosion, but the underside of the car does not, perhaps it was saved by the undercoating.
The steering components would not take any grease and the shocks/steering stabilizer was original and toast; all are slated to be replaced including the trackbar since this is a solid axle car. The brakes had been replaced in the past, but the brake hoses had definite signs of dry rot on jackets. All were removed and replaced making the car much safer to drive.
D. Wheels/Tires:
4 ea. Toyo Open Country III A/T Tires (225/70/16)
4 ea. Vision Overland M2 Wheels (16x8.5)
20 ea. Black Spline Lugnuts
The tires were not original (though the spare which is covered and inside the rear of the car is) and all had deep cracks and dry rot. Tire choices were very limited in the OEM size of 215/75/15 so new Vision 16x8.5 wheels and Toyo 225/70/16 tires took their place. We plan to install a small lift on it next summer so the 16” wheels will offer more options for larger tires when that time comes.
With all of the work that has been done and parts replaced, we are less than 8.5K into it and I have seen many of these cars go for much more than that with substantially more miles and the same worn parts. Given the number of replacement parts and overall low mileage, I think he will have a vehicle that will last for a while.
In the end, it was more about spending time together and doing those things that I was never able to do with my own father that made this a special time. We are nearing the finish line and I will post a few photos of it in the coming days.
Most aftermarket led headlights are illegal and cause excessive glare. The quality is all.over the place. With that said looks like a great project. Was the original owners elderly? Seems like really low miles for the age.
Agree, but these are not. They are non-glare and DOT compliant:
https://www.holley.com/products/electrical/led_lighting/retrobright/parts/LFRB150
My neighbor bought it a few years ago from an estate sale and with the starting issues did not drive it much or very far hence the low mileage.
I went with the Prestone All Makes 15YR/350K stuff which is pre-mixed to -50°F. My concern (aside from any compatibility issues) is that he will be across the country from me. Since the green stuff is what was originally specified if something happens that he needs to have someone repair it, that is what they would probably install and cause a myriad of issues.
I've owned two 2000 Cherokee XJs and they were both great vehicles. I had a 1990 Cherokee XJ as well. NAXJA is a great community and I was a member for several years, lots of knowledgable people there.
I would stick with the TG16 filter personally, there really is no advantage to running the larger filter, besides maybe a tiny bit more oil capacity, which isn't an issue on this engine since it holds 6 quarts already. There are a few 4.0L's running around with 400k miles that just used the cheapest oil and filters available changed at the proper intervals.
Sis had an '88 Pioneer 2-door. Primary red/grey interior with white wheels! The ultimate 'cute girl' vehicle.
Also, a '99 Sport 4-door. Black/ grey interior with 5 5-spoke alloys.
Both bought used. Both had the 4.0l, 4 speed and NP242 TC.
Neither ever needed brakes (Dad told us how to drive easy)
I did what the OP has done except for the suspension work.
How much have you spent so far on parts/supplies?
The original plugs were champions and the ones with the coil pack instead of a distributor are very picky about plug type. It does not use a pcv valve but has an orifice of special size that tends to plug up then they blow oil every where. The grommets on top of the valve cover get hard and leak. New ones are at every auto parts store.
The 0331 heads from 99- early 2002 model year often crack and leak coolant into the oil directly below the oil fill cap. If it hasn't already it's probably ok.
These xj's run hot!
Carry a spare crank sensor and the tools to change it.
First....That is a steal of a price! The XJ's are really increasing in value and a low mileage one that is in decent shape can easily cost north of $10k. $3,000 is a bargain! As a long time XJ fan and owner...here are some thoughts.
People get nervous about the cylinder head. If it has lasted this long it is probably a good one. Just don't overheat it and it will last forever. I would recommend replacing the radiator as preventative maintenance. Get an all metal one if possible. You get what you pay for.
Also, replace the fan clutch as well. An OEM one will be fine but if you want a little extra cooling, look up the "XJ HD fan clutch upgrade". The exact details escape me but a fan clutch from a ZJ or WJ V8 is a direct bolt-in. It engages the clutch a bit sooner and blows alot more air. It may reduce MPG a tiny amount due to the extra drag but it helps cooling quite a bit.
For a small lift with OEM ride quality, you can buy OEM springs and shocks for the "Up-Country" package. It was a 1-1.5" lift package from the factory and allowed for 30" tires. Anything higher than this and you will need to start thinking about adjustable upper and lower control arms to retain the factory suspension geometry. Keep in mind with any lift you may need extended sway bar end links also.
Also above about 1.5" you will need an adjustable track bar to keep the front axle centered.
Above 2" of lift you may experience rear driveline vibrations due to a less than ideal pinion angle. There are two ways to fix this. The best but most expensive option is a Slip-Yoke-Eliminator kit (SYE)...Tom Woods Driveshaft is the place to go. Or you can lower the transfer case an inch or so and put some shims under the leaf springs to correct the pinion angle also.
