I've had the starting aid (starting fluid, brake cleaner etc) punk me when it's a mixture issue. I had a '14 Rogue with bug fried to MAF that sometimes would start (but it ran poorly, although not so bad that your typical oblivious driver might notice) and sometimes not.
Basically the ECM was just REALLY confused and adding a fuel altered the mixture enough to get it to sputter. I nearly condemned the fuel pump but I knew the pump was running and that diagnosis didn't sit right with me. I finally tore out the back seat and cobbled into the fuel supply to verify pump pressure was good.
OP should listen for the pump to prime at key on and find a way to verify fuel pressure -- I don't remember if the bubble bodies got a Schrader valve. My '07 2V 4.6 F150 only has a data PID for FRP - fuel rail pressure.
