Originally Posted By: Russell
I did two treatments of ARX and then ran MMO in my oil at a later date. I thought there was some cleaning from ARX and possibly MMO but not a lot. For example I still have varnish. Also, I have some lifter noise and possibly vanos noises.
It sounds like auto-rx and MMO did not work for you, from what I have read on this board, it seems auto-rx does not do a good job removing Varnish and the product either works very slow or it does not work at all.
I am wondering how long you used MMO in your oil, sometimes it takes a few OCI's with MMO in the oil to see results.
Quote:
I have now started to try Kreen as an engine cleaner. Google for source and/or check posts on this forum. I am only 250 miles into a 1,000 mile clean before an oil change but i see no harm and my engine seems to be getting quieter.
It seems like Kreen is working for you.
Quote:
I will be changing my valve cover gasket, with new plugs, later this summer so i will be able to see about varnish removal.
If there is still some Varnish, do you plan on running Kreen again.
