Hello,
Ok, Here is my UOA for the Truck.
Truck is driven 110 miles a week in One day. Drive about 1.5 miles to freeway (Got one light to have to deal with
) then 52 miles at 2000 rpm (75 mph speed limit then 70 mph) then 1-2 miles around town.
Truck is driven well (In Normal drive mode, Never sees more than 3000 rpm) and gets 20 mpg in the winter and 22-24 in summer. My record is 26.4 mpg going up to MT.
(not bad for a 5000lb truck at 4700 ft Elev at the valley floor)
Oil was old Tri-syn 5w-30 for seven months and 3500 miles. So this UOA was durning Winter months. I just had to get it out.
Changed to 10-30wt Pennzoil Dino (at .69-.99 cents a quart on sale) and AC-Delco Pf-59 filter.
I'm going to keep 10-30 durning the march to sept-oct and 5w-30 Pennzoil Dino for winter.
Here is the UOA. (Thanks Terry for the Excellent service!!!)
******************* Start *******************
Dyson Analysis
Oil Brand/Weight : Mobil5w-30
Type Equipment : Chevy Silverado
Miles/Hours on oil : 3500
Total Miles/Hours : 23500
Results ppm/% Comments (blank=normal)
Wear
Copper 27 Normal GM attribute and low to boot
Iron 9
Chromium 1
Lead 2
Aluminum 2
Silicon 0 Yes 0, none
Tin 2
Additives
Molybdenum 2
Sodium 7
Magnesium 1130 unusually high but I am seeing this in Mobil products at am increased level
Zinc 651
Potassium 16
Phosphorus 574
Calcium 763
Physical Properties
Water negative
Fuel negative scale negative,trace,positive
Antifreeze negative
(Very happy since my other car which is a ford had this postive)
Soot/solids 0
Oxidation 52 scale 0-199 26%
Nitration 134 scale 0-199 67 % elevated
Sulfur 0
TBN 9
Vis@100 C (cSt) 10.1 30w
TAN na
********** End of Report)
Ok, What do we think? Am I crazy to go to Dino like I have? Should I sell my Rare truck and get a Yugo?
(I'm 6ft 6" so that's a NO)
Thanks for everyones comments in advance. Any questions?
Bill
[ March 13, 2003, 08:16 PM: Message edited by: Bill in Utah ]
Dyson Analysis
Wear
Iron 9
Chromium 1
Lead 2
Aluminum 2
Tin 2
Additives
Molybdenum 2
Sodium 7
Zinc 651
Potassium 16
Phosphorus 574
Calcium 763
Physical Properties
Water negative
Antifreeze negative
Soot/solids 0
Sulfur 0
TBN 9
TAN na
Bill
