2000 Nissan Filter Suggestion
Indiana
I'm about to place a large order for suspension parts for my truck, and so while I'm at it, I thought I'd buy some oil filters for my 2000 Nissan Altima.
I'll be doing approx. 8k OCI's with synthetic oil.
Here is what they offer:
FRAM Part # DL7317
Oil Filter FULL FLOW - SPIN-ON [Wholesaler Closeout - Private Label Pkg. - 30 Day Warranty] (Only 1 Remaining)
$1.23
PENTIUS Part # PLB7317
$1.64
PRONTO Part # PO4612
$1.64
HASTINGS FILTERS Part # CF240
Oil Filter w/FUEL INJ
$1.91
AUTO EXTRA Part # 61857356
$2.56
MANN Part # ML1008
$2.66
ACDELCO Part # PF2057 {#25014568, 25161878, PF1222}
FILTER,OIL
$3.04
BOSCH Part # 3323 Premium; O.D. 2.69"; Inside Diam/Thread M20X1.5; Height 3.52"; Gasket Attached
$3.55
MAHLE Part # OC707 {#OC196} Spin-on; 86.00mm Height
Spin-On Oil Filter; Height: 86.00mm; Outside Diameter: 69.00mm
$3.62
FRAM Part # PH7317 Full-Flow Lube Spin-on; Extra Guard; Includes Gasket (Rebate/Promotion Available!)
$3.63
DENSO Part # 1501009
DENSO is the O.E. Manufacturer
$3.69
MOTORCRAFT Part # FL822 {#F32Z6731A, KL0714302B}
$4.37
BECK/ARNLEY Part # 0418135
$4.59
BOSCH Part # 72179 OE Equivalent
$4.75
WIX Part # 57356
$4.77
MAHLE Part # OC196 Spin-on
Spin-On Oil Filter; Height: 85.00mm; Outside Diameter: 65.50mm
$5.57
FRAM Part # TG7317 Tough Guard® Full-Flow Lube Spin-on
$6.03
FRAM Part # HM7317 Full-Flow Lube Spin-on; High Mileage
$6.25
FRAM Part # XG7317 X2™ Full-Flow Lube Spin-on (Rebate/Promotion Available!)
$6.74
BOSCH Part # D3323 Distance Plus
$9.12
Or do you think it would be best to buy something completely different from somewhere else?
Thanks for the help!!
Originally Posted By: Garak
Given those prices, it's hard to ignore the Hastings for bang for your buck.
When I clicked on the "info" button for the Hastings filter...it showed a picture of a Casite filter.....I'm not going there. Maybe they just used a Casite pic instead of the Hastings?
personally I would probably roll with Mann, Mahle, or Motorcraft from that list... tho $6.74 for Fram XG is pretty good.
It might be worth a phone call or an email. Some sites are weird like that. I use some that just show generic pictures of everything. Then, another I use all the time has the actual picture of everything. For example, if I look for a Bosch 3300 for my G, it has an actual picture of a Bosch with the 3300 part number visible on the filter in the picture, believe it or not.
