1. 2000 Civic si B16a Vtec- 141,xxx miles
2.Manual states:API SJ 5w30
3. Located in Upstate NY
4.Generally I drive slowly, lots of city. High is cruise control. A few times a week the car sees above 8,000 rpms. Upgrade Cams are in its future.
5.Daily driven, 1250ish miles per months
6.No known problems
The previous owner had been running only mobil 1 5w30 synthetic. He sated it burned about 1.5 quarts between 3k OCI. Which is not uncommon for a B16 engine.
Upon purchasing the vehicle, I routed the PCV system back OE specs, that should help from his almost non existent PCV system.
I have changed the oil with Rotella T6 5w40 syn, (had 4 quarts left from my wrx).
With a Mann filter (new at work and wanted to try) I usually run a PureOne.
Locally T6 is about 22$ for 4quarts, fine by me.
Curious to see what oil members would recommend for the high revving 1.6! I am open to ideas and to try new oils.
I have been considering the G-oil 5w30, but have read some not so great posts on it.
Thanks!
6.No known problems
Thanks!
