dnewton3
Staff member
Originally Posted By: Pablo
Originally Posted By: dnewton3
What I do think is a possibility is that continued high Cu readings due to "leaching" (more often accepted as flaking or chelation) could mask other "disasterous" events.
Thanks. Just to be clear Amsoil will not cause "flaking" of any engine parts. Copper Chelation can with with most all motor oils that contain esters. Look at some Redline Deisel used oil analysis. Chelation is at the molecular level - the copper is held in solution and detected in a used oil analysis.
Allow me to be more clear, please, so I don't mislead others. The term "flaking" is not well defined, so I'll be more specific.
There are lots of Asmoil used oil analysis (especially in some specific engine types) that exhibit Cu readings significantly higher than "normal". By "significant" I mean I can show examples where the Cu is on a factor of 10x higher, and occasionally 100x higher. (Yes, I have seen a full used oil analysis that had Cu approaching 1000ppm where the OCI was not extended). Seeing 200ppm, 300ppm, 500ppm is not uncommon upon the initial application of Amsoil in some applications. Not all, but certainly a reasonable amount to where many people post used oil analysis with fear and bewilderment, on this site and others. ("Fear" and "bewilderment" are fair terms for the concern and complaints I've fielded from others.)
I will use the term "gross" to mean an extremely exaggerated magnitude here. Having grossly high Cu readings can mask other undesirable events that would otherwise show up in a used oil analysis, but become overwhelmed, masked, and basically disappear as "noise" when the Amsoil causes Cu spikes at such levels. That is undesirable in my book. Further, Blackstone has stated that such extreme levels of Cu (regardless of source) can be detrimental; I tend to agree, but Amsoil does not.
Yes, this phenomenon calms over time. But that "time" is often a factor of significant mileage accumulation (tens of thousands of miles). The higher the initial spike, the greater the time needed to "normalize". That can be averted by the frequent OCI with Amsoil, but it becomes quite expensive to do some "flushing" OCIs with $9/qrt oil! So, you either put up with the "spikes" for 50,000 miles (two extended OCIs) or you pay through the nose. Neither is an attractive option to me.
However, my main discontent with some of the other posts here was about the unqualified or unquantified comments of "disasterous" Amsoil. It's not fair to use such a label without explaining what is meant. Not for one second do I believe that using Amsoil will result in a "disaster" that results in catastrophic equipment damage. Many of Amsoil's products are quite awesome when used correctly with the understanding of benefits and limitations, and can be very effective and worthwhile.
There are two topics at play here:
1) Amsoils effects on a used oil analysis
2) Amsoils effects on equipment
I don't like how Amsoil can skew results and mask potential problems, but I do not believe that using Amsoil will directly result in "disaster". Using Amsoil may, however, hide the evidence of some other cause or effect of disaster. What I take exception to is the comments from some other members in this thread that would lead some to believe using Amsoil in itself will lead to "disaster"; I find no proof in that whatsoever, and those comments are clearly not well defined in quality or quantity.
That make it more clear?
