2000 VW Jetta 53000 miles on oil with Amsoil bypass
Colorado
Below are all the results of oil analysis from my 2000 VW Jetta TDI. The highlight of this are the 53,000 miles I used Amsoil Series 3000 5w-30 (HDD) with an Amsoil BMK-11 bypass filter, between 46,000 and 99,000 miles. The car was chipped. Notice how quickly I piled on the miles on this car. Most miles were with Flying J or similar truck syop diesel fuel. The most recent sample was with mostly long trips and almost all high quality Amoco Powerblend 47 cetane diesel. I think I could count the number of cold starts on one hand, so its not suprising the numbers are very good. Not exactly a fair comparison to the Amsoil HDD before. I will also add that at 120Kmi, one of the HDD 5w-30's biggest critics in the TDI world did a compression test and tested compression values at 550,555,550,545 and noted how spotless the engine was inside. Regards, Brian
code:
Date		10/7/01	7/26/01	7/6/01	6/10/01	3/10/01	12/26/009/5/00	7/1/2000
Miles Unit	121710	109500	104500	99200	82000	67300	46000	18884
Miles Oil	12086	5000	5000	53000	35800	21100	21600	8500
Oil Brand	CAT	Amsoil	Amsoil	Amsoil	Amsoil	Amsoil	Amsoil	Mobil
Model		DEO	AMO	HDD	HDD	HDD	HDD	HDD	Delvac 1
Vis.		5w-40	10w-40	5w-30	5w-30	5w-30	5w-30	5w-30	5w-40
Vis.	100C	14.3	12.2	10.8	13.6	11.1	11.6	11.9	14.9
TBN		8.3	8.5	12.4	12.3	12.1	12.2	11.9	5.9
Fe		15	17	15	43	45	46	66	57
Cr		1	1	1	2	2	2	2	3
Pb		0	3	0	1	1	1	1	1
Cu		1	1	1	3	4	3	5	9
Sn	Tin	1	1	0	3	1	1	1	1
Al		5	9	5	10	9	10	12	14
Ni	Nickel	0	0	0	1	0	1	1	3
Ag	Silver	0	0	0	0	0	0	0	0
Mn	Man	1	0	0	1	1	1	1	1
Si	Silicon	4	6	3	4	4	5	6	11
B	Boron	115	21	59	26	27	22	54	271
Na		0	3	2	0	1	1	1	5
Mg	Mag	558	26	16	19	22	24	92	497
Ca	Calcium	1994	4387	4351	4388	4339	4364	4319	2289
Ba	Barium	0	0	0	0	0	0	0	0
P		1039	1297	1280	1291	1273	1284	1263	1120
Zn		1145	1372	1343	1351	1344	1390	1340	1226
Mo	Moly	0	0	0	0	0	0	0	6
Ti	Titani	0	0	0	0	0	0	0	0
V	Vanadiu	0	0	0	0	0	0	0	0
Cd	Cadmium	0	0	0	0	0	0	0	0
	Potas
GLYCOL		NEG	NEG	NEG	NEG	NEG	NEG	NEG	NEG
% H20		<0.05	<0.05	<0.05	<0.05	<0.05	<0.05	<0.05	<0.05
%FUEL		<1.0	<1.0	<1.0	<1.0	<1.0	<1.0	<1.0	<1.0
%SOLIDS		NA	TR	NA	NA	NA	NA	NA	NA
%SOOT		<1.0	NA	<1.0	1.7	1.2	1.1	2.6	<1.0
%OXD		6.7	27.8	<1.0	21.1	30	18.9	12.2	17.8
%NOX		8.9	5.7	20	18.6	17.1	12.9	18.6	14.1
[ July 13, 2006, 07:56 AM: Message edited by: brian ]
brian
Colorado
The engine was filled with fresh oil 9/5/00. Between 9/5/00 and 6/10/01 I put 53,000 miles on the oil. I thought some might find these results interesting. -brian
South Denver
Brian - Where did you tap in to the system and return back to. I have an Oil Gaurd that I want to install on my 02 TDI. I wa thinking of getting the oil from the oil sender and returning it back via a hollow drain bolt. The hollow drain bolt could be a pain for oil drains as it would have to be removed. I would also loose the use of my Fumoto valve.
