rrrrrroger,
Ok, mea culpa but I'd of said "Mr. Flippant".
I had a point, more than just to call ya' out or just to point at your problems as a personal attack, so first: sorry - my bad.
I've got a feeling that there's some parallels between you and I and I also feel strongly that the facts in the case should be brought to light.
My short statement was just that: too short. This one may be too long, so... TL/DR short OCI is good, LONG OCI is BAD.
My [censored] car that I did not like to drive was an oil guzzling, 18 mpg, slow as molasses, no fun and cantankerous 1986 mazda b2000 pickup that consumed a qt every 2 fill-ups (roughly 450 miles). I bought it cheap, put WAY too much money into it rebuilding it after the previous owners had run it into the ground and basically gave it away when I bought my new car that I like.
So let me respond to your post at this point.
Originally Posted By: rrrrrroger
Dear Mr. Vain:
Asked and answered, see above.
First off: Who cares?
You should, anybody who read your original post in this thread should, anyone who is thinking that excessively long OCI's are good, or that neglecting basic car maintenance is ok should. You may have more in common with your brother than you think and he certainly should.
The 87 Plymouth was inherited from my mother.
A zero cost car is easy to do cavalier experiments on. I see where some of your attitudes may have come from.
It was a nice-looking car but it ran like crat (bounced up and down on the road due to its weight & soft shocks). I didn't enjoy driving it at all. And it only got a lousy 22mpg which is expensive when you have $4/gallon gasoline.
As above, but mine was worse. And I let it lead me into the money-pit syndrome. I feel your pain.
My replacement car gets 55-60 so I'm saving about 7000 dollars over the next decade.
That's really good gas mileage. What car, please, and is that a combined # or just hwy?
AS FOR OIL CHANGES: I switched back to doing 5000 mile changes, and the engine still wore out. It wasn't the OCI that damaged the car "chief".
Let's look at the first post in this thread and see what we can discern:
I decided to try an experiment and run my car (1987 Plymouth Caravelle) for 20,000 miles on the same oil. Of course I used the best oil I could find: Mobil Delvac 1 (synthetic/5W-40/diesel oil). I then got an oil analysis to see what kind of results I got, and I think it looks good:
4 quarts + 1 quart makeup oil
14 aluminum
4 chromium
45 iron
8 copper
13 lead
4 tin
62 molybdenum
2 nickel
1 manganese
0 silver
0 titanium
4 potassium
3193 calcium
312 magnesium
1123 phosphorus
1638 zinc
0 barium
89.0 SUS viscosity (should be 65-78)
As some others in this thread have pointed out, there are some things that would be interesting to know in addition to what you have posted here: TBN - probably zero, but who knows? And without TAN, even a TBN would be tough to interpret, especially to call an analysis "good".
Insolubles: more of the same.
Silicon: Mildly high, as per Blackstone, but no number, even after a request and some discussion from you.
Here is what the lab said:
"Sometimes we have trouble finding things to talk about. Not so here! Metals read high, and we think that's primarily due to the long oil change. Average for this engine is 3400 miles, so you're going all out at 20,000 miles. Silicon was mildly high. This may show a dirty air filter, which would cause high wear. So check that out. Too early to call yet; use 10,000 miles."
Question about oil(sic) filter:
Don't dirty air filters provide *more* filtering than clean ones? So I would expect less dirt. Also, wouldn't I notice if the engine was starving for air due to a dirty filter?
But the most telling point of the original post is the makeup oil added over the OCI: One quart over 20,000 miles and from an answer later in the thread we see that is roughly a one year interval for you.
Originally Posted By: pbm
How many months did it take to accumulate 20K?
I don't remember. I guess one year (since my last State inspection).
So, at the time of your first post post, you had - in your own words - a good analysis, a really good consumption rate and a good running car, even though you didn't like it much.
Now, a handful of years later, doing - as you stated above - 5k OCI's since then, which is 4 per year or so, with good oils, 5K OCI's would be only 1/4 qt consumption after your "good" analysis. But something changes(abruptly?) So that a trip from CT to MD uses up all the oil and your neglect causes it to blow up? Your car suddenly began using a quart every 200 miles? Really? Does this not seem a little far-fetched to you?
(I ran my other Plymouth cars 10,000 miles on this same Delvac 1, and one last 360,000 miles. The 96 model still runs as if it were new.)
Why did you decide on 5K for this one, then? Or decide that 20K was a good experiment to try and that it turned out good? And let's be sure that everyone knows that the 360K car was not without issues its whole life:
My car:
- blown head gasket at ~150,000 miles (common problem with 80s-era Dodges; A result of mismatching steel engine with aluminum head)
- valve tap at ~200,000 miles
- I didn't want to spend thousands fixing old car.
- So I kept driving.
- the valve finally "broke off" after I passed 340,000 miles
- engine blown
Used Pennzoil natural for first half of the car's life, and Mobil Delvac 1 for the second half of its life. I think if I had not used Delvac 1, the car would have died sooner.
Engines do sometimes die.
(edited for content: thread here -
https://bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Main=83729&Number=1085090 )
I'm glad your '96 is doing good. Maybe you haven't done whimsical experiments with it.
It was AGE that killed the 87 Plymouth. That's what happens when the previous owner only drove it 20 miles a week & the new owner doesn' drive it all summer. The seals become damaged by the short trips & after 25 years aging, they dry out.
Ok, we're getting a little deep here, so everyone put on your wading boots.
You've had it for about 4 years, you're running 20K a year. So mom put about 20 miles x 52 weeks x 21 years: 21,840 miles. Blew up at 80K so you put about 60K on it.
Back in '08 you said it was running good, VERY low oil consumption, "good" analysis.
NOW, you say it was short trips that killed it. Do you see the disconnect here?
But for some reason you decided to start running 5K OCI's after a 20K "good" OCI. Please tell us exactly when the oil consumption started.
I'd hazard a guess it was directly after this errant experiment and even Blackstone said you should run only 10k on this oil.
As you mentioned about your brother, there's got to be more to this story.
I understand that this was the winter beater? And that you drove the nicer car in the summer so that it sat; and your parents and Marilyn Vos Savant said not to?
http://www.bobistheoilguy.com/forums/ubb...956#Post1073956
So which is it? The short trips? The age? The sitting? When did it happen? Something doesn't quite add up.
Mechanic explanation:
'The engine was running rich. The reason it was running rich was because oil was getting into the piston & being burned like gasoline. That's also why you kept having to add a quart of oil every 200 miles.'
So, again, when did the consumption start?
I would have taken it to the garage for repair, but with 7-day workweeks it wasn't possible. The engine was full of oil when I left Connecticut (where I work) but by the time I was in Maryland it had run dry & died.
I was working 7 day work weeks too, when mine was using about half as much, but seriously, no oil light came on? You never knew it was consuming? You just didn't give a [censored]?
Jeez. Nothing peeves me off more than people who blame the driver. It's a _____ 25 year old car. They don't last forever. And I like the replacement car much, much better.
Like I said, you and your brother may have more in common than you think.
You blew your car up after you ruined your car with a misbegotten experiment.
I'm glad you like your new (Insight, is it?) car better, I like mine better too.
