( Caps are just for emphasis, not shouting
2cycleguy- Two cyle machines are not "jetted for a richer oil to gas ratio", they are jetted to precisely match the volume of air coming through the venturi of the carburetor, the ratio is about 14.7:1, that is 14.7 parts air to 1 part gas. If you put in a larger jet, it will run richer, and a smaller jet will cause it to run leaner. My point is that the jet has nothing to do with the gas/oil ratio, and everything to do with the 14.7:1 stoich ratio. The stoich ratio is completely different than the gas/oil mix ratio.
Boraticus- Thank you for not being rude, I will try to do the same.
Air cooled two cycle engines "requiring" or "not requiring" a specific oil ratio is probably the number one most confusing thing about these engines. I have been selling and servicing these engines for more than three decades, and we STILL get asked "What ratio does my engine take?"
In fact, this was a very confusing concept EVEN TO OTHER SMALL ENGINE SHOPS. We would get calls from customers telling us that they talked to a different repair shop, and get this, they told the customer the ratio was DETERMINED BY THE COLOR OF THE ENGINE. Can you believe that? It wasn't done out of malice, it was simply ignorance.
In the early days of 2 cycles, before specific oil was developed for them, a 16:1 ratio was widely used with 30 weight standard engine oil. In fact, that ratio was molded right into the gas cap of many/most chain saws, and it provided plenty of lubrication for the early slow revving saws. Then in the late 50s and early 60s some of the manufacturers came out with some like-branded two cycle oils. That is to say there was McCullogh oil, Homelite oil, etc. The idea being, of course, that you would naturally want to run the same brand oil in the same brand saw, right?
Flash forward to the mid seventies, and you have all kinds of different oil brands and ratios floating around. Homelite had a 16:1 oil. a 32:1 oil and a 40:1 oil, as did many other brands. NO WONDER THE CUSTOMERS WERE CONFUSED. And because the ratio is determined by the oil, you could have used any of them mixed at the ratio on the bottle and done well. Why did they have three diff ratios? Very simple, there was a move to leaner ratios but they didn't want to alienate/lose customers. Eventually, the richer mixes were dropped and people have now embraced the leaner mixes.
OK, as to your 30 yo race bike that "required" 25:1. Point number 1)-When a manufacturer develops and then sells a piece of equipment like that, they have to tell the public SOMETHING about what ratio to use, right? And this was back in late 70s and early 80s when there were several diff oils and ratios being used, so they simply picked one of the richer ratios ( 25:1 ) and adopted that as a fallback position. MANY companies would put a ratio sticker right on the engine, implying that was the only ratio you could use. Point number 2)- It was VERY COMMON to see a given manufacturer recommend an oil ratio and then offer that exact ratio to the consumer in their brand. And why not? It's another way to make a buck, get the customer buying a consumable item from you and only you, because you're the only one with that ratio. Genius move, really. All the manufacturers did the same thing, they convinced the public that you had to use their brand at that ratio. Special emphasis was used when talking about warranty.
Another point, I have seen dozens of small engines plugged with carbon because the owner used some 32:1 oil and mixed it 16:1, BECAUSE HE THOUGHT HIS ENGINE REQUIRED A RATIO OF 16:1, when he should have mixed it 32:1, which is how the oil was designed to be mixed. Again, the ratio comes with the oil, not the engine.
Also, how is it that I have dozens and dozens of customers that are still running their 30-40 yo equipment that are using the modern 50:1 ratio with Stihl oil? I mean, according to you these engines were "designed" to run on rich ratios( the engine determines the ratio, according to you ), and yet they are thriving on the leaner ratio? I still have a guy with a Homelite EZ that says 16:1 right on the cap, he's doing just fine with the 50:1 oil. Just today I put a chain on an old Craftsman that has a 32:1 sticker on it. Guess what oil this guy is running? That's right, Stihl oil at 50:1.
I have rebuilt more AC two cycle engines than I care to admit, and guess what? They are all built with the same exact tolerances, and have the same basic lubrication requirements. Very similar to the lube requirements of my Toyota and my Mustang, basically the same.
And btw, I'm talking about typical air cooled equipment here, not racing stuff or exotics.
Your belief in different equipment requiring diff ratios is rooted in your long experience. Back then that's what people were told, "if you buy this mini-bike, then you have to run X ratio." Those long held beliefs are the hardest to break, I get that. It's very similar to people hanging on to the 3k oil change, that's what they grew up doing and it's deeply rooted in their belief system.
There used to be( maybe there still are ) some 2 cycle oils that you bought in a quart bottle that had a ratio chart right on the back of them. Big fail, because you can't mix a given oil at different ratios and have them all be optimal. THERE IS ONLY ONE OPTIMAL RATIO FOR A GIVEN OIL. You can't take a given oil and mix it at diff ratios and have them all be the optimal mix.
You get that, right?
Lastly, why do all modern oil mixes tell you exactly how much gas to put with a given amount of their oil? The bottle will say "Mix this oil with one gallon of gasoline", for example. It's because the oil manufacturer/blender has determined the correct ratio.
The mix ratio is determined by the oil. Period.
This will be my last post in this thread, take care
