First does anyone else wear gloves when they change oil. For instance I get those throwaway gloves at the grocery store. I find that the dirt doesn't get under your fingernails, as well the oil normally takes many hand washings (sp) to get off.
Also I try to replace the crush washer each time. Is this overkill ?
Another trick, when I drain the oil I pour it in a 6 gallon gas can. It makes it much easier to dump when the time comes.
