Originally Posted By: Kawiguy454
With all of the responses none ever explain the physics of why to put them on the back? ...just because some source says so.
It's well explained by tire rack and most people aren't up on the physics, been a while since I've been to a class. But basically the advice is sound, the new pair is always supposed to go on the rear regardless of FWD or RWD. For FWD, the real problem is that the rears will swing out unexpectedly when they lose traction and you end up fish tailing. If the bad tires are on the front, the front starts to slide out first and you can correct for it. Although with stability and traction control, it might be a moot point if the OP has those options.
