I rotated the tires on the Burb for the first time (7,500 miles) about a month and a half ago and when doing a once over on them the week before last I noticed that the front tires had slightly less tread than the rears. When I bought the vehicle, the PO had recently put on two new tires and the other two were in dire need of replacement. I am not positive on how long the new tires were on there before my purchase but believe them to be a few weeks max with little driving. Not wanting two sets of tires with different handling and wear characteristics or tread wear warranties (locking me into a loop of purchasing two tires at a time), the two new tires I purchased were the same brand, model, and size (1" taller than OE) of the two newer tires, making all four Falken Ziex S/TZ04. I bought the tires at DT and their policy is to put new tires on the rear so the tires that are now on the front and have about 1/32-2/32" less tread (even wear on all four tires) are theoretically the two newer tires that spent all but the last two weeks on the rear.
If it matters, I ran the tires at about 40-44 psi (OE is 35, max pressure on the tires is 44); the normal load is one or two adults in the front, an infant and her car seat in the middle seat, two small children and their car seats in the back seat, and a stroller in the back, resulting in a fairly light back end; driving is probably 70/30 to 60/40 highway/city; the driving style is mostly tame with no burnouts, no sliding around corners, and only one 5 mile offroad trip; and a front end alignment was done shortly after buying the two newest tires.
Is there something that could explain greater wear on the rear tires or is it more likely that DT put the new tires on the front, seeing as the tires being replaced were up front and the rears were still pretty new?
