Thanks to Blano for his advice on not mixing 2C oils- sounds like I'd be better off using Mobil MX2T or Schaeffer, but not both at the same time.
I know little about 2C engines, the questions here all pertain to my own equipment:
1. Huskqvarna 51 chain saw, bought new June '97, surely less than 3 or 4 hrs run time on it. Original owner's manual says lowest rec'd is 90 octane gas, mix 50:1. *Later* manual says lowest rec'd octane is 87.
2. Stihl FS-80 trimmer, bought new July '02, more run time than the saw, manual says at least 89 USA pump octane(90 RON), mix 50:1.
3. Homelite Vac Attack II blower, bought new yesterday(10/25/03), manual says gas for automotive use of 87 octane or higher. Mix 50:1.
Questions:
Octane: Is it best to run Super Unleaded in all of these machines? In general, is more octane better?(within pump gas limits of 93 octane or so). I'm now using Chevron 93, good or should I switch.
Break-in: It's too late for the saw & trimmer, of course, but would I be better off to mix a full tank at ~32:1 & use all of that for a break-in tank for the Homelite blower? It now has Chevron 93, w/ Schaeffer 2C conventional oil at ~45:1 in it. also: Is it normal for a new engine, w/factory settings, to rev kinda slow? The Homelite started easy & ran smooth yesterday, but didn't seem to rev as fast as I'd expected. Might this take care of itself after a tank or two is run through it?
Fuel stabilizers: I have on hand Schaeffer Neutra, Fuel Power, & Stabil. Any experienced recommendations on which is best, & how long I can trust a mixed gallon of gas to be useable?
*Anti-Owner devices*: the new Homelite Blower has plastic gizmos on the High speed & low speed adjustment screws to prevent them from being turned counter-clockwise from the factory settings. Any idea how I can get these off withoug damaging the adjustment screws?
Gas
il Mixture: Since I've learned recently that the 50:1 mix is largely due to political correctness, would I be better off to just use a richer mixture of 40:1, 32:1, or somewhere in-between for all these machines? Will a richer mixture really give more power due to better compression? Will richer mixture lower rpm?
And last: do all these questions remind anyone else of the Gilda Radner, "Roseanne Roseannadanna" skits on on the Saturday Night Live shows of long ago?
[ October 26, 2003, 03:35 PM: Message edited by: Stuart Hughes ]
Questions:
Gas
