The simplified lapse rate is generally considered to be 3% per 1000 feet. So a normally aspirated engine will lose about 15% power at 5000 feet elevation.I wonder how it would compare with the V-8 as you add altitude? I live at 5050 above sea level. I wonder how it would do say with a load going up I-70?
A 355HP Chevy 5.3L would make about 301HP
A 420HP Chevy 6.2L would make about 357HP
At about 10000 feet the 6.2L would make the same HP as the 2.7 turbo 4 at sea level
However, even though turbo engines can be tuned to make rated HP at reasonable altitudes, they typically fall short by almost 1/2 what a normally aspirated engine loses. The turbo needs to run at ever higher RPMs to achieve rated boost as we increase elevation/altitude. This increases turbine inlet pressure (exhaust back pressure) and reduces output.
