- Joined
- Nov 23, 2020
- Messages
- 516
The torque is impressive ...... this truck will most likely never tow any significant weight but the bed has a decked slide out platform and and our best attemp to weigh the amount of tools and wire is about 925lbs give or takemy 2.7 eco has the 36 gallon tank. It’s not a crew cab but the extended cab. Seriously it’s not a truck I’d let a younger person drive - it has gobs of power - even for interstate passing it pulls, and absolutely will spin out say, in the rain if you goose it at 55, which is not good if an inexperienced driver gets over-excited in it. the engine seems stout; but as I’ve said before I’ve had a few hiccups with the transmission, and mine has leaked coolant at the turbo line o-rings.
with the Chevy 2.7, how is the torque? I mean, i don’t drive with a lead foot; I wanted the torque of the 2.7 for towing, at which it is Fabulous. The turbos do the work, and it pulls similarly to a small diesel. How does the Chevy do with a load behind it?
My other trucks are F250 thru F450 for towing so I'm used plenty of power and this truck does not disappoint I also have 2.7 tacoma and let me say this 2.7 vs 2.7 not even in the same solar system
