1ZZFE Plugs
ME
Unknown time spent in my 2002 corolla. 170k on engine, burns a quart of 10w40 every 500 miles. No codes, running "ok" but I feel it stumble on gulps of oil after decellerating. I stuck in some barely used iridiums I pulled from my camry.
typical oil burning, fouling the plugs, fix the oil return holes and your issue is resolved.
1zzfe rebuilds are my specialty.
Runs same as before.
It's a slushbox so all hope is lost, really.
It's a slushbox
how is it a slushbox? It's actually a pretty good engines, makes good power and decent fuel economy.
Yours just needs a DIY oil consumption fix without honing the cylinders, the post is on toyotanation.com
Lol eljefino you are the champ at being a cheap-skate in car repair (in a good way). I think it's awesome how you fix your cars so cheaply, such as using Camry spark plugs in the Corolla.
Originally Posted By: 01_celica_gt
It's a slushbox
Slushbox = automatic transmission.
+1
Why pull it apart and replace stuff that isn't broken?
I'm also a terrible pack-rat.
The camry plugs might be a heat range colder but I run this thing at 75 MPH most days so it should work out.
I'll admit, I have learned a TON from Eljefino. Nothing wrong with a great member like him. In this day and age, saving money helps
Originally Posted By: Papa Bear
When did the 1ZZFE go from dual ground plugs to single?
I had a '98 Corolla 1ZZFE and the manual said "DO NOT USE SINGLE GROUND PLUGS"
I haven't changed them yet on my wife's '02 Corolla (only at 98k miles) but the listed replacement Denso plugs are only single ground.
98-99 corolla/prizms were dual ground copper plugs(this is the non-vvti version, with spark plug wires)
00-08 corollas/00-05 celicas & spyder mr2/03-08 matrix & vibes use the single ground iridium plug (these are the vvti version with coil over plugs)
