The above seems to contradict your earlier statement:
It wasn't meant to but these are some very fine lines/points and the distinction can get lost within the confines of a post. I can see where it could be viewed that way so let me try again.
I believe the poster who asked the question was simply asking whether a more vicious oil might leave behind a more robust or longer lasting oil film, which might contribute to less noise at startup.
But if *all* oil falls to the pan as you suggest, I'm certainly curious how startup noise is affected by oil viscosity.
The big thing here is the
distinction with a difference between a "film" and an actual accumulated volume of liquid ( which has all the damping and hydraulic properties of a liquid) and the other DWID of viscosity being defined as a
resistance to flow- not its "thickness" (per se)
The left behind oil film is all but worthless for much of anything relating to this- the remaining bulk liquid trapped inside what amounts to a journal bearing ( pin/roller area) means a lot.
I did a test earlier on two of my kids' bike chains. Sitting out in the cold, about 30F or so, I poured a half capful of 5w-20 and 15w40 on a 2" section of each chain. About 3 hours later, I came back and ran my hands on the chain, and the one which I'd applied the 15w40 to had a noticeably thicker oil film on it. "
I would counter that in relation to the subject discussed that the test is in no way represented of the actual conditions of the subject matter. The bike chain's tension ( relative to the timing chain) is unknown. The chain was not subject to centrifugal and mechanical forces. The viscosity of the oil wand components were not at operating temperature.
Based on all of the above, I have to call the test invalid.
am still trying to get my head around the conclusions of the senior posters...
I can only say this ( and yes this is ALL with industrial chains- none with automotive but a chain is a chain)
I have been commissioned to design, implement, troubleshoot and problem solve thousands of chain drives from conveyors to pulp/paper to mining. I have worked with every major manufacturer on this planet in doing so. I use every technology that exists as well as teams of other SME's to evaluate these things and get answers. I also do laboratory level RCFA on these systems after the fact. I have a very good understanding of what I am saying and hundreds of scenarios to base it on.
All that to say this as I also pointed out. There are ways to analyze these noises and not only determine the conditions creating them but actually pinpoint them physically along the chain/sprocket path ( just like we can do in vibration) when we employ multiple technologies.
Once all that is done, the corrective solution is often easy to create. ( as much as the working system will allow- some chain drives by virtue of what they do destroy a chain group and its a run -to- fail thing)
So, in this case- without all that "stuff" on the noise in question, this is all speculation based on hunches and that's good. It puts fresh ideas out there and makes people think out of the box. That being said, that's not an excuse or reason to go down every rabbit hole because even with a broad based claim like we have- certain facts can be reasonably gleaned from it.
Simply put there are certain things oil can and cannot do for a chain. "Film strength" ( specific to this thread and the common use on this site) is not one of them.
Hope that clarified it a little better.
