This is my first UOA and i hope to receive some feedback from the results.
Truck is a 98 GMC Sierra 4x4 with 5.7L.
Truck had 191015km at sample date.5038km on oil and filter. Oh and oil was in service from Sept 25/04 to March 25/05. Lots of short trip winter driving in southwestern Ontario. The analysis was done by Wearcheck.
Now the numbers....
Silicon 13
Potassium 90
Sodium 13
Fuel % Glycol Pos
Water % Soot -
Sulfation 77
Nitration 67
Boron 124 Base 94
Barium 0.2 / 0.0
Calcium 2550 / 820
Magnesium 116 / 1388
Moly 63 / 0.0
Sodium 13 / 0.0
Phosphorus 815/ 720
Sulpher 1769 / 2240
Zinc 943 / 780
Visc @100*C 10.1 / 9.9
Oxidation 76
Tan -
TBN 5.95
Iron 11 Abn 150
Nickel 0.2 / 5
Chromium 1.4 / 20
Titanium 0.0
Copper 3.1 / 155
Aluminum 3.7 / 40
Tin 1.2 / 10
Lead 3.2 / 50
Silver 0.2 / 2
Wearchecks` comments are as follows;
" Although the glycol test was pos. other chemicals other than antifreeze can cause a similar reaction including the oil additive package, or supplemental oil additives. As there is insufficient evidence such as high wear metals, or the presence of water to indicate a serious leak, no other maintaince actions, aside from those recommended here should be carried out at this time. We reccomend you drain the oil from the component if this has not already been done. Check for low coolant level. We reccommend an early resample to confirm this situation,however a minumum of 10 hours, 500 miles or 800km on the oil is required before resampling to prevent a false glycol reactions that can be experienced with new oil.
After the sample was taken i changed oil and filter with a fresh fill of XD3 0w-30. I also have an appointment next friday 29 to have the leak repaired ; i think it is the dreaded intake gasket leak. Did i leave any information out that could help??
Comments and suggestions welcome and thanks to everyone for a great forum!!
Steve
Now the numbers....
Silicon 13
Potassium 90
Sodium 13
Fuel % Glycol Pos
Water % Soot -
Sulfation 77
Nitration 67
Boron 124 Base 94
Barium 0.2 / 0.0
Calcium 2550 / 820
Moly 63 / 0.0
Sodium 13 / 0.0
Phosphorus 815/ 720
Sulpher 1769 / 2240
Zinc 943 / 780
Oxidation 76
Tan -
TBN 5.95
Iron 11 Abn 150
Nickel 0.2 / 5
Chromium 1.4 / 20
Titanium 0.0
Copper 3.1 / 155
Aluminum 3.7 / 40
Tin 1.2 / 10
Lead 3.2 / 50
Silver 0.2 / 2
Steve
