Originally Posted By: Trav
I would take the mechanics word for it. Rebooting is easy enough you just need a pliers to crimp the clamps, they don't cost a lot and can be found online or in parts stores.
This one will do the job for $10.
http://www.autozone.com/test-scan-and-sp...ers/141501_0_0/
Thanks for the link. It's quite a bit more here
http://www.princessauto.com/en/detail/cv-boot-clamp-pliers/A-p8160335e
If I get the used one, is there any way I can tell if it has issues? just twist it to see if it clicks?
A new boot kit usually has grease included.
How do I clean up the grease in the joint area?
I also noticed there are some that looks original(3 ribs) and some universal ones that has 4-5 ribs.
Isn't the more ribs the better in terms of flexibility?
The tool you linked to is heavier tool, its better tool but for a few uses on this light duty clamp its not necessary to buy a better one, you may also be able to rent one.
The amount of ribs are not as important as the material used for the boot, OE is probably a poly boot which are very durable and good for +100K, neoprene ones (most aftermarket) are much easier torn and damaged, I suppose its possible the more ribs make on this type are more durable but I really don't know.
To check the joints, you feel for roughness and rotational play, turn it one way then then the other, there should be no play, rotate the joint in a circular motion, it should be smooth.
I never used Raxale but Cardone is rubbish, they grind the surface hardness out of the joint and their new ones are cheap Chinese.
To clean the joints, remove the boot and just wipe out as much of the grease as possible, a small amount left in it wont cause any issues if the boot was intact.
I looked up the boot material. Rockauto sells boot kit that are all neoprene, the only poly one is the split boot, obviously not going that route.
Unless I order the boot from Honda which is listed at around $70 vs $25 for Beck/Arnley.
I'd move it around, although I'm not sure if a clicky one would be felt, unless if it was real bad. On the flip side, if you install and it does click... you can then rebuild your old axle in the meantime.
There are youtube vids on rebuilding the CV. I looked at a few, but the main jist is... towels. Lots and lots of towels. It's a messy job, and I bet some mechanics just don't want to deal with it. Get a big roll of paper towels, tear of some to have handy, grab some disposable gloves and place the trash can real close by.
Have you looked into how to do the axle yourself? I'm sure some are easier to do than others--I don't know anything about your car. When I did mine I bought the socket for the axle nut (lucked out, a fleamarket find) and hit it with my Earthquake impact wrench. It took several minutes but it came off. Jack car up, drop onto stands, remove wheel. I think caliper and rotor stayed on, but ball joint bolts came out, then pop the bolts on the axle (I had to get triple-square tool, that I had to get off Amazon). Bit of fuss but eventually the axle came out. Reverse for install. In my case there was some odd tightening sequence for the axle nut, but I suspect a great deal are simply hit with the impact. Again, you might luck out and find a good vid on youtube for your exact car.
Edit: errm, forget if you wanted to do this job yourself or not. If not, ignore the above. Just get the old axle back from the mechanic and attempt the reboot job yourself. Perhaps after waiting to see if the used axle is problematic.
In terms of DIY, I'm missing:
axle nut socket
cheater bar for breaker bar on the axle nut
pry bar for getting drive shaft out
heavier hammer to take the CV joint off
I still have to re-boot or replace with the used OE axle. Just the time used for all this, the mechanic can get it done in an hour.
Plus the amount of time that I'd have to put into this in the unheated garage.
I am debating between the 2 paths.
1. Get used OE axle, mechanic puts it in and hope for the best
2. Get used OE axle, re-boot it first so that the boot is less likely to torn and put it in
Does the second path even make sense?
