1998 Caravan Diff Fluid change Redline mix
va
So there was only once source of information that I could find my googling as far as the capacity of my diff. The source said that the rear diff held .7 quarts of fluid. This didn't seem right but I can't be sure since the Factory Service Manual says nothing about it. So I did the next best thing in my mind. There is only one drain/fill/inspection plug on the rear of the diff. I filled the diff with fluid until it poured out of the fill hole.
Unfortunately, I only had 2 quarts of Redline 75w-90 which I thought would be enough for the job. I ended up adding about .5 quarts of Redline MTL I had laying around which is 70-80 GL4.
So I guess 20% of the fill is Redline MTL. Do you think I will be ok?
Do I need more additives? I am not too woried about the weight but maybe I should be.
The diff is non lsd. Chrysler spec is 85w-90 for the rear diff but everyone else says it is 80w-90.
I have some mopar LSD additive laying around but not sure if that will help.
Is this mix ok, or did I take it too far?
Thank you
Considering how many Caravans go through life without getting any fresh gear oil in there I doubt it will turn into a real world problem. Usage conditions make a difference, though. If wheelspin is something that vexes you daily, maybe try not to run that mix for more than 30k or so.
Want more opinions please now that I clarified. Thanks...wheelspin lol 180 hp on an AWD...wheelspin won't be a problem.
Come on guys, please provide me with some more opinions now that I have let you know the vehicle is all wheel drive. Not second guessing Yonyon who has helped me out in the past. Just want more thoughts. Do I need to drain this now that I know the capacity is much greater than listed and go buy 3 more quarts of redline? Expensive, but the rear diff costs more than the minivan! Maybe I can go buy an additive?
Thanks
Thanks LargeCarManX2...gotta wonder if the 90W on other oils is subject to sheer anyways like motor oil...maybe even bringing the weight down to 86-88W like I probably have in there anyways.
What I am more concerned about is the lack of additives....being GL4 for 20% of it, I now have 20% less of the GL5 additives.
Thoughts on that one Large?
Thanks
Originally Posted By: LargeCarManX2
The fluid you mixed is just a tad bit lighter that spec....I would not worry about it because you are running a very high quality fluid....Redline!
Thanks
GL-4 has been used in many applications from keeping certain metals from attack to keeping syncros from grinding, however....it still protects gears, bearings, etc!
