1997 Toyota Avalon Valvetrain Pics
Originally Posted By: Oregoonian
But why 5K OCI's on M1 and PU. Seems to me like an awful waste of $$$ and good quality oil.
Try 7.5K....and do a used oil analysis. I'm sure both those oils are capable of longer OCI's.
Oh sure why not go 20k.....
Originally Posted By: johnachak
Originally Posted By: Artem
With only 115k miles in 15 years, I'd expect it to be clean. It's been barely used!
Nice engine regardless. I'd dump come Kreen in there to "polish" things up a bit and keep it clean if it was me.
As clean as that engine is, you would still dump a chemical in there for no apparent reason?
I wouldn't consider the left side to be clean. There is build up starting to happen in the corner, (the same spot that my 1MZ has build up).
To me, a clean block is one without any kind of build up or discoloration. Just my opinion.
I really want to know if PU is really better at cleaning than Mobil 1 Extended Performance. I have put Mobil 1 Extended Performance into an older Camry and will take the VC off to see the cleaning it has done. Then do another interval with PU to see if its any better. Thanks for the responses!
Stop being so sarcastic...and stupid to boot !
FYI....both Mobil 1, Pennzoil Platinum and Pennzoil Ultra are rated for 10K....under the right conditions and driving habits.....so 7.5K should not be a streach.
+1. Why mess with success? I have no trouble running my Mobil 1 Extended Performance 6 months and 3800-4300 miles a dumping it right outta there.
Really clean.
A little light varnish, which is harmless.
Toyota sure didn't waste any time or money doing any machining on those areas of that didn't have to have any.
