1997 Chevy Cavalier still wont pass emissions... What now?
the knockoff fuel injectors got me past emissions but it's now dying at idle.
That's a bummer. Do you still have the old injectors? I wonder if you could send out for rebuilding on the cheap. If not, when does it have to pass emissions again?
I thought most states plug into the OBDII and tell the emissions to do a self test?
Yeah most sane states just plug in to the obd port. States that had inspection stations with sniffers already set up probably didn't want to get rid of them as private businesses had already invested in the equipment. I'm looking into semi retirement in New Mexico and they smog test in the county that I would be living in. There are dozens of testing locations in Albuquerque alone. I don't see that changing as dozens of businesses would be closed. The obd check should have been the gold standard from the beginning.
  • Love
Reactions: D60
In Colorado there's no emissions testing for the first 6-7 years, then an obd plug-in for 5 years or so then a dyno drive test. Heavy trucks and 1981 and older get a static tail pipe test. Then hybrids and certain vehicles i.e. long wheelbase, and a few vehicles that can't have traction control turned off only get obd tests. For some reason the Corvette ZO6 is obd only yet other Corvettes are a drive test.
