1996 MB E300D - M1 T&SUV 5w-40 12824mi; 199k total
JHZR2
Staff member
New Jersey
Yet another... our 96 MB E300D. Ithas just under 200k at this change. Yes, we skipped a few UOAs in between.
Anyway, a bit disapointing... soot seems up and thus wear is up a bit too. No LC, #132 or similar used here. Apparently there was a fair amount of stop and go traffic driving on this interval... as well as winter driving. It still returns between 32-36 MPG, with a high of 38.
Anyway, here is current (left) as well as older ones to the right:
Code:
Sample Date 6/22/08 2/27/05 9/11/04
Unit Age 199742m 157087m 149127m
Comp Age 199742m 157087m 149127m
Time on Oil 12824m 7960m 3867m
Time on Fltr 12824m 7960m 3867m
Oil Maint. Changed Changed Changed
Fltr Maint. Changed Changed Changed
Fluid Mobil1 Truck&SUV (Delvac 1) 5w-40 Mobil1 Truck&SUV (Delvac 1) 5w-40 Mobil1 Truck&SUV (Delvac 1) 5w-40
Fe 45 27 13
Cr 3.4 1.4 1
Ni 0.7 0.7 0.1
Ti 0 0.2 0.1
Ag 0 0 0
Al 4.8 3.5 2.6
Pb 0.5 1.1 0
Cu 1.5 0.9 0.6
Sn 0.4 1.2 0
Si 6.8 6.3 5.8
Na 1.3 1.1 1.5
K 0 0 1.4
B 40 44 36
Ba 0 0 2.2
Mo 2.2 2 2.4
Mg 457 426 347
Ca 2404 2264 2029
P 1173 1185 973
Zn 1308 1228 1073
S 4158 3651 3417
Cd 0 0 0
Mn 0.3 0.3 0.2
V 0 0 0
Sb 0 0 1.1
Soot(%) 0.5 0.3 0.2
Oxid(PA) 63 80 70
Nitr(PA) 91 40 25
Sulf(PA) 56 0 0
ZDDP -0.06 -0.06 0
TBN 8.23 10 10.2
Kv@100°C 13.2 13.6 13.2
White Metal NONE NONE NONE
Babbitt NONE NONE NONE
Precipitate NONE NONE NONE
Silt NONE NONE NONE
Debris NONE NONE NONE
Dirt NONE NONE NONE
Appearance NORML NORML NORML
Odor NORML NORML NORML
H2O(Emul) NEG NEG NEG
H2O(Free) NEG NEG NEG
Hi,
JHZR2 - This is an excellent report. The uptake rate for wear metals is outstanding, the TBN is great and viscosity has been consistent. IMO it is always a good idea to obtain a TAN for diesel engines
This lubricant will handle soot at a much greater level than most lubricants and in any engine family too
Your report is excellent and IMO the lubricant could have remained there much longer
Thanks!
That is the goal... its more or less only a highway car, so Im hoping to do over a year, maybe 20k miles next...
Hi,
JHZR2 - The UOAs from my Porsche 32v V8 (M28 engine) were consistently indicating a two year OCI was quite feasible - almost regardless of the distance
The greatest distance I went in one OC1 (1 year) was around 13k miles - I calculated that the lubricant was capable of another period about the same before changing
This was consistent over many OCIs and is the same with my
Boxster
In my Series 60 Detroits in City work I could only get around 12 months (40kkms) due to soot contamination (4%)
Doug Hillary,
What did you use as a condemnation limit for TAN? I've heard it is a good rule of thumb to change out the oil when the TAN/TBN "equalize", (i.e, approach the same number), but would like to know what you used for limits.
Thanks in advance,
REDDOG
Hi,
REDDOG - The highest TAN (one truck) was 7 and it's lowest TBN (D4739) was 2
The average of all TANs was 6 and the lowest TBN was 3
Detroit Diesel's condemnation limits are 1 (D4739) or 1/3rd of new lubricant. No TAN is given. Delvac 1 5W-40 had a TBN of around 11
I used 1 as my "base line" TBN (and 8 for TAN) - however the limits for Soot or Iron were always reached first even when using a centrifuge cleaner
I always found that by getting both TAN and TBN I could detect some "irregularities" perhaps coming from the Labs I used (Mobil and Castrol)
