1996 I30 brake light problem even with new bulbs
USA
When the lihgts are off (headlights off, taoil lights off), the right brake light is very dim compared to the correctly-functioning left brake light.
When the head/tail lights are on, the right brake lights don't work at all!
I had something very similar, turned out to be a cracked brake/taillight bulb holder. The globe would move and the dual terminals on the bottom would cross and cause pretty much exactly what you said.
I fixed it by replacing the looms
I agree, you probably have a corroded wire somewhere. You might need to start to remove the rear trunk panels to find out where the wires run and where the bad wire is.
I had an old 84 Toyota Tercel. One day I closed the driver door and the door ajar light stayed on. I eventually tracked it down to a wire in the rear hatch that rusted out and caused a short.
The holder isn't cracked. Only one of the contacts looked bad. Tracing this is going to be a nightmare
