I have a 94 escort that is leaking a lot of oil into the air cleaner from the engine vent tube. I replaced the PCV valve and emissions filter in the air cleaner box but I still is leaking bad. I also see a little oil leaking from the oil cap too. Is there a way to fix this leak cheaply? Somone told me that the oil is likely blow-by, because of worn piston rings and that is expensive to fix. This car has 169,000 miles on it with 4 cylinder 1.9L motor. Is there any temporary fix to get me by for a couple of months? What if I detached the tube going to the air cleaner and plugged the hole were it was plugged in and routed the tube to a pop can or someting metal to catch the oil?
Thanks for your help.
