Originally Posted By: 95busa
Overkill, thanks for the advice. Looks like oil pressure sending unit, fuel filter, pcv and trans service in the near future.
No problem.
Fuel filter is easy as pie to change as long as the bolt holding it isn't rusted to heck, which it shouldn't be. It has the little pull clips on it.
For the PCV, I cannot stress enough that you need to get the PCV SCREEN as part of what you are replacing. So you want the screen, grommet and valve. All Motorcraft. The screen plugs solid and renders the entire PCV system non-functional, which leads to sludge and varnish as well as blow-by. Many of the guys who had those types of issues (dirty engine, sludge, blow-by....etc) with the 302 had them because of this. If anything was changed, it was just the valve, which did absolutely nothing due to the plugged screen.
I have a story about that actually with respect to the 302 in my Town Car. It was my dad's car, serviced primarily by a garage in town back when we lived down east. In the late 90's, when the car was less than 10 years old, I had of course moved out and gone to school, so wasn't involved in the maintenance of my parent's vehicles anymore.
Several years later, my dad gave me the Town Car when I had kids. Figured it was a more appropriate child mover than the Mustang, and he was quite right on that one. I noticed the engine, which had been regularly serviced, and many times with Mobil 1, had quite a bit of blow-by. I found this interesting, as at the time, the 302HO in my Mustang, which had been beat-on like a red-headed step-child its entire life, didn't have any blow-by at all....
So I started digging into the PCV system and pulled out the ORIGINAL PCV screen. This was on a car with more than 300,000Km on it. It was plugged SOLID. CAKED with varnish. I fired the engine up with the screen removed and you could hear what sounded like freakin' WIND coming out of the grommet. "Oh great" I thought........
So I went up to Ford and bought all the parts I recommended you buy and then started running M1 0w-40 and Delvac 1 5w-40 (I had both in my stash) in it and beating on the car pretty hard seeing if I could clean-up the ring lands and get the blow-by under control. The contents of the oil filter seemed to confirm this was working.
A while later, a buddy of mine bought a freshened 302HO (for the shortblock) out of a Mustang that had been wrecked. I scored the heads off of it, which had been milled and had all new hardware on them. Bought a set of ARP head bolts, an Explorer intake, Lightning EGR spacer, what I thought was an HO camshaft (ended up being an E-cam, came out of the same engine as the heads came off of) and a 65mm throttle body and went to town on it. Had to swap the ECM to one from a Lincoln LSC to run the 19lb injectors and HO firing order, but the car didn't run right (low vacuum) and that's when I used a dial indicator and mapped the camshaft, discovering I had an FMS E-cam. Lovely
So then I converted the car to MAF with an A9P ECM from a Mustang, which involved a bit of wiring, but ultimately left me with a proper running warmed-over 302HO in the car. I continued to drive it hard and the blow-by continued to reduce to the point that it was no longer significant. It was never as good as the engine from the Mustang, but it was a LOT better than when I started.
I will add that internally, the engine with the baffed PCV system looked nothing like the 302HO from the 'stang, which was immaculate, despite them having essentially the same mileage on them when torn into. It had some funky deposits in the lifter valley, which I cleaned out, and the heads had some varnish on them, as did the valve gear.
So I've said all of this to stress that the PCV operation is very important, and don't forget the screen!
