Sounds like a great car!
- Pull the silencer (no need for an aftermarket CAI on the Fox cars, they do absolutely nothing)
- 3.73's with the auto
- Baumann shift kit in the AOD to firm up the shifts a bit. I'd recommend using the "stage 2" setting that it comes with, as that's what the guy I gave my Town Car to used and it really woke it up.
You could also upgrade to a 3G alternator (the stock one is awful) and an electric fan, but that's your call. Makes the car a bit more responsive and the upgrade to the charging system is necessary with the E-fan or if you plan on running an aftermarket stereo.
I did underdrive pulleys plus the small 2G alt pulley on the 3G alternator so it charged at idle. Gave me a solid 1Mph increase through the traps.
- Base timing is 10BTDC and you gain a couple HP by bumping it up to 14 or 15, but this also usually requires you run 91 octane.
- Subframe connectors are a great idea. The Steeda ones are excellent.
If you are going to do aftermarket wheels you might want to consider upgrading the brakes to 03/04 Cobra brakes and running 5-lug. Makes a HUGE difference as the stock brakes suck.
This is what the Cobra brakes look like (this was my buddy Nate's car):
5 bolts were the first thing I noticed.
Good call on the alternator. Iirc the Taurus from the early 90s was a bolt on. I've got cobra r 4 bolts on mine. Brakes aren't great but the extra tire helps.
A cai doesn't do anything on a speed density engine,just like overkill has said.
Don't play with the idle screw. A nightmare will ensue including checking voltage to the throttle body motor and a ton of time.
I had timing at 15 degrees. Mine would rev right to 5000rpm sounding fine but above that it sounded like it was breaking apart. I figured I wasn't pegging it past that rpm anyways. 91 octane. I'm sure you can get another degree or 2 with 93 octane.
Advancing the timing really helps the off idle take off and low rpm. Remember to pull out the plug before adjusting. Lots of articles and pics about advancing timing on those engines.
