1986 BMW K75C, Amsoil 20W50 MCV, 4238 miles
Metro Atlanta GA
Over all I'm pleased with the results. Ran the oil almost 2 years. Might have to track down the silicon issue via the air filter intake system as BlackStone suggests. Only VOA I've seen of Amsoil 20W50 MCV didn't have that amount. They also suggested that copper was a little high relative to the universal averages for this type engine and might be the result of dirt ingress from the induction system.
Code:
EQUIP. MAKE/MODEL: BMW Motorcycle 740cc OIL TYPE & GRADE: Amsoil 20W/50
FUEL TYPE: Gasoline (Unleaded) OIL USE INTERVAL: 4,238 Miles
ADDITIONAL INFO: 1986
Amsoil 20W50 Castrol 20W50
MI/HR on Oil 4,238 1,450
UNIT /
MI/HR on Unit 17,365 AVERAGES 13,075 UNIVERSAL
Sample Date 07/14/11 11/30/09 AVERAGES
ELEMENTS IN PARTS PER MILLION Make Up Oil Added 0 qts
ALUMINUM 3 2 1 2
CHROMIUM 1 1 0 1
IRON 6 5 3 10
COPPER 8 6 3 3
LEAD 2 2 1 2
TIN 4 2 0 0
MOLYBDENUM 50 46 41 39
NICKEL 1 1 0 1
MANGANESE 0 0 0 0
SILVER 0 0 0 0
TITANIUM 0 0 0 0
POTASSIUM 1 1 0 0
BORON 23 111 198 108
SILICON 12 8 3 5
SODIUM 2 2 1 3
CALCIUM 3144 2533 1921 2040
MAGNESIUM 28 47 65 157
PHOSPHORUS 1166 916 665 918
ZINC 1412 1101 789 1119
BARIUM 0 0 0 0
Values
Should Be*
SUS Viscosity @ 210°F 85.6 82-95 68.7
PROPERTIES cSt Viscosity @ 100°C 16.90 16.0-19.4 12.62
Flashpoint in °F 375 >385 395
Fuel % 0.5
Antifreeze % 0.0 0 0.0
Water % 0.0
Insolubles % 0.3
TBN 8.6 7.2
TAN
ISO Code
Amsoil was also ran 2.5x longer so it could have thinned down and then thickened back up... who knows.
I'm glad it looks good on the used oil analysis report though
Looks better than my K75C on Mobil 1 15W-50 for 4000miles. I see 30+ppm of Iron in my oil. Not sure where that Iron is coming from but I am at 138,000miles and running good so I don't worry too much.
The Mobil 1 also cut down to a thick 30Wt.
scatter scatter.....jeeez when will they do a decent calibration?
sillycon of 12 in 4200 is pretty decent. i would not worry.
nice report! at a 2 year oci, run that stuff till you or the bike dies. probably you first! keep the rubber side down!
wow castrol not in grade. that is a real shocker. oh wait i think i proved that to be the case in 2005!
steve
Originally Posted By: sunruh
...till you or the bike dies. probably you first!....
Given the longevity of Bricks that's the truth.... Gonna have to put it in my will.
I had 28ppm Iron in my 86 K75C running Mobil 1 15W-50 for 4000miles...
Maybe My Brick will disolve before me!
Running Rotella T6 5w40 this oci just for a test as Shell makes some sleeper oils and others have run this oil in their Bricks. Depending on the results in shear and wear numbers will probably go back to the Amsoil.
Originally Posted By: ammolab
... Not sure where that Iron is coming from ....
Probably the crankshaft, alternater, oil/water pump, and secondary shaft drive gears. Also I've seen in my own used oil analysis of Mobil 1, as well as others, it seems to throw slightly higher iron numbers. Speculation by some here on BITOG is it's slight reactive to iron.
Yep, and or the camshafts and timing chain and gears. I'm running VR-1 now and may sample at 2000miles as I will take forever to hit 4000 like the M1. I have a new bike to ride daily.
