Originally Posted By: hattaresguy
You need some DOT cheater slicks to get that M5 to hook up!
That's the problem with big power RWD cars, 600ish is about the limit. More than that and you start to have traction problems.
That's why a Veyron is AWD, only reliable way to put 1k hp down.
Huh? I replied then thought about it. For a road car, that's very true. A road based suspension will have trouble putting down the power with out some mods that are major tradeoffs.
A F1, Indycar, or NASCAR all have in excess of that and have lots of grip and very low weight, except for the stock car. With the right suspension setup 600 hp is just the starting point!
Indycars in the 70s had 900+hp, F1 in the 80s had 1.5L turbos with 1500 hp in qualifying trim, Can-Am had Porsches and Chevrolet powered McLarens with 1500 hp.
That's what makes it fun! A 125 cc shifter kart is a good way to experience the same feeling.
Maybe I'm a little nuts, but Mark Donohue (Penske's first driver) said, you only have too much power when you can lay rubber down at the exit of one corner into the braking zone of the next.
