Originally Posted By: jdawg89
I'm just a little nervous about syn. In such an old motor that's always had dyno. And rotella 15-40 will not work in winters up here...LOL.
This is the oil-recomendation chart for your engine:
If you don't want to change the oil type, just go with a name-brand 10W-40. Stay away from store brands, which could sometimes be poor-quality. Whatever major brand on sale is a good way to save money.
If you really want a fancy oil, go with Mobil 1 0W-40 but it will be expensive unless it's on sale.
10W-30 dino should also be OK.
Going from dino to synthetic shouldn't hurt anything -- not much different than changing the oil brand.
High-mileage oils are also OK.
Chances are that even modern dino 5w-30 (as opposed to early-to-mid 80s dino 5w-30) is OK. Synthetic 5W-30 (which doesn't shear as much as dino 5W-30) is definitely OK. Virtually any oil should be OK for this engine.
PS: It's funny that in the chart footnote they put 5W and 5W-20 in the same very thin category, while OKing sraight 10W. It gives you an idea on how much early-to-mid 80s multigrades sheared -- 5W-xx oils shearing to perhaps almost 5 weight. This is no longer a problem with modern multigrades and chances are that even a modern 5W-20 or 0W-20 would be OK with this engine.
