I have a 1976 Volkswagen Bus / Kombi / Transporter with a stock 2L engine including stock flat tappets (no hydraulic lifters). It’s Australian delivered so it’s dual Solex carburettors and no exhaust gas recirculation equipment. The only modification is an external oil filter and oil cooler. The stock internal oil pressure relief valve and internal oil cooler are still in place. The engine was rebuilt about 10,000 km ago.
I’ve purchased Royal Purple HPS 5W-30. The current oil is Penrite Racing 10; an australian 100% synthetic with about 2000 ppm ZDDP. It’s a 10W-40 and it runs cooler now with the extra oil cooler; between 80 and 95 degrees C (down from 105 to 120 degrees C). I’m getting 45 PSI at 2,500 rpm (70km/hr) which is a bit too much because the oil pressure relief valve starts to open at this pressure and that bypasses the internal oil cooler. So that’s why I’m going to 5W-30. Hopefully about 45 PSI at 4000 rpm (105 km/hr) when oil is 85 deg C.
I’m not worried about the extra cost of high quality. I just want an awesome oil that keeps my engine in great condition. I can only get Amsoil Z-Rod in 1L bottles which is just annoying. And the RP HPS is available in 10W-40 which I may need to use in summer. I can’t buy Mobil 1 Classic 5W-30 in Australia. Penrite has been great, but being a racing oil I’m not sure about detergents for long term use.
Is the RP a mistake?
