I have a 70 Monte Carlo with a 396 big block in it. I've been reading about how the newer SM and SN oils don't have enough Zinc in them to protect the cam on a flat tappet engine. This engine is pretty much stock except for it being bored out .60 Cam is stock.
I'm currently running 10W-40 Havoline conventional in it. I've tried a 10w30 in it but the engine doesn't seem to like it and oil pressure is not where I want it. Engine probably only has 15,000 miles on the rebuild.
So what oil should I run in this engine? No synthetic recommendations please. I also want to stick to a 40 weight.
Are there any additives that you would recommend instead that can be added to the oil to add some Zinc back into it.? Thanks for any information.
Wayne
Wayne
