1st time running the No VII Euro, so I figured I'd take an in-service sample from the Stahlbus valve I installed at last oil change. How convenient! Going to roll these out to all my other vehicles even though it's essentially $50/per.
Anyways, back to the sample. Looks like just under 2ppm Fe/1k, and we know from @RDY4WAR that this oil has Al in the virgin form (I'm going to get the OA from my specific batch if possible), and that viscosity has crept up just a little; it's on the lower edge of a 40 grade now. Still have plenty of TBN at 7.8. Also of interest, AFAIK WearCheck uses GC for fuel %, and my sample was <1.0% with 0.1% soot. This result is even with a 5 Star Tuning tune on it... I generally run at least E15 (UNL88) when available, and when I'm near a Casey's or Sunoco, I will mix up something close to E30. Not sure what the copper is, and if it's even a concern, since older UOAs were in the 8-10 range and the Universal Average for Cu on Blackstone is 16ppm.
Where I need some advice, @wwillson or @dnewton3, is the nitration, oxidation & sulfation. They are all slightly above the "limits" but were not flagged- I colored them yellow for visibility; at what point is the actual concern? Also, I see my silicon is a little high (but was at 21ppm 50k miles ago with the same filter); this will be remedied at next OCI since air filter now has about 58k and 3.5 years on it. I will be going with the S&B dry filter for my CAI.
Still waiting to hear back from @High Performance Lubricants on a couple questions, but what's the consensus? Continue to run this oil & re-sample at 20k, or drain now at ~15k? Last note, my very first Fram Endurance 10575 is still along for the ride; now over 22k miles. It will change with the oil, and C&P once that's done. Anyways, hoping this and future UOAs can help to change the (false) mentality that 3.5 EcoBoosts are a "5k or else" affair...
Post Script: Here's some nuggets for everyone who thinks that lower mileage OCIs are a holy grail... Everyone remembers Navi, who enjoys 3-5k maximum OCIs because otherwise, his EBs are going to die a horrible death, right? Well, I grabbed a couple of his older UOAs and my old Ravenol UOA and crunched some numbers. At the bottom, I also summed up Navi's 4 runs since they came out in almost identical mileage to this single HPL run as a comparison.
Even with the Al "skew" from the virgin HPL, on a per 1k mile basis, my engine is making 12% less aluminum, 30% less iron, and 35% less copper. Or, to look at it another way, four oil changes (cost, time, inconvenience, etc...) vs. one and you'd still end up with more average wear. Thoughts?
SAMPLE INFORMATION | Unit of Measurement | Reject Limit | Result |
Sample Date | 03 May 2024 | ||
Machine Age | miles | 82988 | |
Oil Age | miles | 14394 | |
Oil Changed | Not Changed | ||
CONTAMINATION | |||
Fuel | >4.0 | <1.0 | |
Water | >0.2 | NEG | |
Glycol | NEG | ||
WEAR METALS | |||
Iron | ppm | >150 | 29 |
Chromium | ppm | >20 | <1 |
Nickel | ppm | >5 | 0 |
Titanium | ppm | <1 | |
Silver | ppm | >2 | 0 |
Aluminum | ppm | >40 | 15 |
Lead | ppm | >50 | 0 |
Copper | ppm | >155 | 11 |
Tin | ppm | >10 | <1 |
Vanadium | ppm | 0 | |
Cadmium | ppm | 0 | |
ADDITIVES | |||
Boron | ppm | 200 | 53 |
Barium | ppm | 3 | |
Molybdenum | ppm | 85 | 732 |
Manganese | ppm | 4 | |
Magnesium | ppm | 525 | 1162 |
Calcium | ppm | 4300 | 2381 |
Phosphorus | ppm | 1000 | 862 |
Zinc | ppm | 1100 | 991 |
Sulfur | ppm | 20200 | 7511 |
CONTAMINANTS | |||
Silicon | ppm | >30 | 25 |
Sodium | ppm | >400 | 10 |
Potassium | ppm | >20 | 1 |
INFRA-RED | |||
Soot % | % | 0.1 | |
Nitration | Abs/cm | >20 | 21.6 |
Sulfation | Abs/.1mm | >30 | 55.9 |
FLUID DEGRADATION | |||
Oxidation | Abs/.1mm | >25 | 48.1 |
Base Number (BN) | mg KOH/g | 11.0 | 7.78 |
VISUAL | |||
White Metal | scalar | NONE | NONE |
Yellow Metal | scalar | NONE | NONE |
Precipitate | scalar | NONE | NONE |
Silt | scalar | NONE | NONE |
Debris | scalar | NONE | NONE |
Sand/Dirt | scalar | NONE | NONE |
Appearance | scalar | NORML | NORML |
Odor | scalar | NORML | NORML |
Emulsified Water | scalar | >0.2 | NEG |
Free Water | scalar | NEG | |
FLUID PROPERTIES | |||
Visc @ 100°C | cSt | 11.19 | 12.7 |
