So, let say... best to get the higher impacting power. Example (numbers are made up, just example):
(forward impact)
get the 750 ft-lb tool, that way, when using extensions, it would reduce down to like 650 ft-lb?
get the 485 ft-lb tool, that way, when using extensions, it would reduce down to like 390 ft-lb?
(reverse impact)
get the 1400 ft-lb tool, that way, when using extensions, it would reduce down to like 1100 ft-lb?
get the 620 ft-lb tool, that way, when using extensions, it would reduce down to like 400 ft-lb?
I think I get it... when using extensions, the impact tool would be working on the socket rather the lug nut. Correct me, in technically, the full impacting torque is the anvil, so anything add onto the anvil (even just the first one socket), the torque is dropped. The more extensions, the more the torque (multiply) drops.
In watching (more than one) YouTube reviews, when they use torque limiting bars, they double check with manual torque wrench, it met the specs. So, the engineers made aware of "using extensions" causing reducing torque measurements? In other words, torque limiting bars are exemption in this case?
