My Turbo S is my daily in the summer. It gets driven more. I actually like driving my F150 more though- less hassle with traffic.100 miles a month means you need to have that car taken away so it gets used properly.
Agreed, this doesn't look right.Something wrong, wear is not normal and oil additives is not from X-Cess 5w40.
There was a time when almost everyone used Blackstone and this would happen sometimes. People started talking smack on BS's "poor accuracy" and said to use other oil analysis companies. I predicted back then that the more people started using other labs, the more we'd see these types of mistakes from the other labs. But because BS was used so often, it made it appear as if they messed up all the time and the other labs never messed up.They tested the results again. The additives changed, but they said the wear results are nearly the same. Makes you wonder if you can trust their results if you have to have the sample retested.
It shows how pointless low mileage UOAs are.They tested the results again. The additives changed, but they said the wear results are nearly the same. Makes you wonder if you can trust their results if you have to have the sample retested.
There’s always a naysayer to rain on your parade too.It shows how pointless low mileage UOAs are.
