Is it okay to run 15w40 on a 2003 Nissan Sentra Ser Spec V (2.5L 4-cylinder) during Spring and Summer? The manual specs for 5w30/10w-30, but 10w-40 is acceptable if you're having oil consumption problems. I burned about 1qt every 2000 miles with 10w-40. The car is running perfect, no blue/black/white smoke during idle or hard acceleration, and no oil leaks what so ever. Pcv valve was replaced even though the old one was working fine. 92k on the motor. Precat looked fine when I replaced it with an aftermarket header at 78k, and butterfly screws were locktite at the same time. No SES or CEL.
I do a lot of driving (average 30k a year) and planning to do some road trips during Spring and Summer that will involve some highway or mountain traveling. If 15w40 was safe on my car, what brand of 15w40 would you recommend? It doesn’t matter if it’s conventional or synthetic as long as it's decently priced and gives adequate results. Depending on the type of oil, my oil change interval is between 3-7k.
