'14 Accord - Honda 0W20 - High vis or lab error?
Raleigh, NC
Are the viscosity readings most likely an error by the lab? For this OCI and the one prior (10/24/2015) I ran Honda OW20 syn. This is a direct injection engine so that might explain some of the fuel. The wear metals look OK to me. I did find the drop in moly a little curious.. is it normal for additive levels to vary like this even using the exact same oil?
The oil is sitting in a catch pan with brake fluid and other oil, so no chance of a re-test.
Interesting. At .06cST over, it's just barely out of spec, but I agree it should have been diluted by the high fuel. Is there a VOA of the Honda oil?
If you're sure an 0w-20 was used, I'd bet on lab error. Blackstone relies on human beings watching oil flow through a viscosometer for this measure, which makes error quite possible (same with flashpoint and fuel %, fwiw). If your driving patterns are anything close to those for previous used oil analysis you would expect considerable shearing.
If you didn't perform the last oil change yourself I suppose the dealer could've used a 5w30 by mistake. On the bright side, given fuel dilution and how these engines can shear oils, an xxw-30 oil may be a better choice anyway.
Are you still getting free oil changes from the dealer?
Originally Posted By: vvolcano
The dealership we bought it from included 6 free oil changes.
KV@100*C of xxW30 is 9.3-12.5 cSt.
Appears to me a Blackstone error.. anyway wear rates looks fine.
Ah thanks for that information-- makes human error seem like the culprit in this case.
I changed the oil myself this time as well as the previous time. Nothing remarkable about this interval.. around 40 miles roundtrip of daily commuting with a couple of regional trips sprinkled in.
